Boost questions
Old Oct 9, 2006 | 05:42 PM
Kwin's Avatar
Default Boost questions
Yea soo i hear all this good stuff about boost and what not
but whats soo great about it,,please explain in detail lol not just you go fast
also what are the risk factors
also wut do u press to use it, do u just open the valve on the thing cause if u leave it open isnt it to much pressure....also if u use a little can u stop it and then use the rest later
thanks the more info the better
Old Oct 9, 2006 | 07:34 PM
frelly's Avatar
Default RE: Boost questions
I think your are mistaking boost with NOS
Boost is when your car has a turbocharger, basically it forces air into your engine which results in more power! The thing is the turbo only "kicks in" at a certain rpm because it needs time to "spool" or in simpler terms get the little "wheel" spinning fast enough to blow air into the motor.
There are some risks to a turbocharged car/NOS but there are other members on here much more qualified to explain them to you.
Old Oct 9, 2006 | 07:38 PM
ScoobyAddict14's Avatar
formerly aryiman98civic
frelly is right, you are thinking of nos and not a turbo. the risks of a turbo on the the car is blowing your engine. if you put the boost up too high then you will blow your engine. if you dont have a good tune, then you will blow your engine and screw up your turbo. before putting one on i would recommend you research a little more. start by reading this:
http://www.beesandgoats.com/boostfaq/g2icturbo.html
Old Oct 9, 2006 | 07:42 PM
Kwin's Avatar
wow thanks soo much you guys and another question comes from this lol
whats the difference between superchargers and Turbos?
*edited* to ask another question lol
well since i have not gotten my car yet and just from skimming through that article it says the stock b20 engine does not handel boost well....soo what year/ model should i avoid... cause my aim is boost on the car
Old Oct 9, 2006 | 08:03 PM
you may boost any car that you want. the difference between a supercharger and turbo is that with a supercharger, you can only go up to like 10 psi i think. but with a turbo you can go up to as much boost as you want.
Old Oct 9, 2006 | 08:31 PM
theonecalledtodd's Avatar
the main difference between turbo and superchargers are....
superchargers run off of your engine turning. A pully and belt is connected to the charger and the other side to your engine. Engine starts, turns the supercharger, bam, boost. You always have boost if your cars running.
Turbos spin and boost off of exhaust gases passing out of the motor. The more throttle, more exhaust. More exhaust, faster spinning, faster spinning, more boost.
these are pretty vaugue discriptions, but i hope it helps
Old Oct 9, 2006 | 08:53 PM
Remmy's Avatar
do a quick skimming of the front page in this section and youll find a bix write up on the differences.
Old Oct 10, 2006 | 12:40 AM
SovXietday's Avatar
My supercharger vs turbocharger post is not 5 posts down from this one.
And I admittedly laughed out loud while reading your first post. Come for a ride in my car and find out why boost is so awesome.
Old Oct 10, 2006 | 02:48 PM
Kwin's Avatar
ORIGINAL: SovXietday
haha yea i do too now that a look back at it
well id be screwed without this site thanks alot guys
ill do a little more research and prolly still have some more questions
Old Oct 11, 2006 | 08:21 AM
Kwin, read that entire article that aryiman98civic posted. That will save you some time in typing out basic questions.
