compression
im looking to run ITR pistons, eagle rods, and JRSC in a B18B, compression is 10.6:1 and running 8psi, is this legit? I want to run the highest compression i can while still being safe to run the boost, i think i can get away with this, just want to make sure.
ORIGINAL: Forty04
Don't konw if it'd be any cheaper/easier, but you could also look into the Cry02 system. I think that if i was going high compression w/ S/C that's probably the route I'd take
