d-series turbo kit on DOHC ZC??
If I was to get a d-series turbo kit what all would I need to change for it to fit my ZC engine(d16a1 I believe) Even though its a d engine I think the years for manifolds being the same is 92-00...maybe? So would I just need a new manifold and some adjustments to the charge piping or is there other stuff I would need?
RE: d-series turbo kit on DOHC ZC??
well i'm not sure if the turbo manifold will bolt up, but if it doesn't, that should be the only thing you have to get a different part of. everything else should still work.
check the forsale on my sig for turbo parts
Also, the downpipe would most likely not be long enough if it was for a d series kit
But I can have a shop make a custom down pipe for pretty easily right? And if I get a manifold from somewhere fitting the 88-89 integra things should work pretty decent? and I already dont have ac/ps so thats not something to worry about losing
yea an exhaust shop can make you a downpipe pretty easy.
it'll be even easier for them in your situation because if you bring the downpipe that doesn't fit
, they can use the flanges from it to put on the downpipe they make. i did a search on yahoo, and it looks like the normal d-series manifold will bolt up.
In this link, it says the HF manifold fits all 88-00 D-series engines, and it also mentions that it also fits the D16A1. Therefore, if the exhaust manifold will bolt up to both normal d-series and the DOHC ZC, that would imply that they have the same exhaust manifold bolt/port configuration. http://www.homemadeturbo.com/tech_pr...old/index.html
stupid forum virus won't let me post very much at a time...
