done my homework, still need help
well i wasn't planning on keeping my 93 Del Sol - S for very long but looks like i'm stuck w/ her for at least a year so i'm beginning to piece together a turbo kit. i've lookin every "what engine does your honda have?" and i can't find a 93 del sol (s) anywhere so i'm not sure what engine i have in there but i know it's a SOHC pos.... i'm sure it can't hold a lot of power so that is the question i have... how much power can i put to the wheels with a SMALL turbo but still remain safe? i'll be putting a t25 or t28 on there (yes i kow how small that is and how much power they can hold but all i want is something to get me enough power to pass a car!!! this thing is rediculously slow). i'l be using a simple SAFC to tune it with. also, do you know how much power my stock clutch can take? i've found a way to get this thing turbo'd for about 1200 and i don't want to put much more into it than that. yes it is ebay product but i dont' care, i shouldn't have this car for more than a year from now. thanks for any help.
it's got a D15B7 with 102 bhp and barely enough torque to tighten the lugnuts.
However i recomend you get a chipped ECU with either Crome or Hondata or Neptune and have it professionally tuned on a dyno. Did you perhaps buy a SSautochrome kit?
And for the clutch however im not sure. but it was only made to be put on a car with 102 hp, i dobut it will be able to withstand the power the car with put out with a Turbo.
clutch will slip over 130whp, and you will make that with relative ease boosted, and you will have a lot of torque with a small turbo like that so you will need new clutch.
if your looking for enough power to pass a car then just intake / header / exhaust it, that will up you maybe 12-15whp (i dont know how well d15's take bolt ons)and you will definately feel a lot faster than you did.
a turbo will definately run you over a grand, your going to need a clutch / exhaust / ecu / gauges / injectors / Fuel managemetn and some other stuff that i garuntee doesnt come in your kit for 1200.. those alone are another grand
ORIGINAL: didder
manifold
turbo
wastegaet
downpipe
IC Plumbing
FMIC
bov
injectors
wideband
SAFCII
boost gauge
fuel pump?????
and a possible clutch. i've street tuned a couple cars and didn't do a half bad job, i'm not looking for a lot of power or else i woudln't leave that pos lil engine in there. like i said i'm just lookin for ssomething quick enough to pass a car.... lol i had greddy evo II catback, self make short ram and a dc performance header on it at one time but trust me... they don't take mods well. in most cars you are looking at a minimum o fabout 10-12whp...i may have possibly gotten 5.
all in need to know is if the clutch can handle about 180-200whp.... and how much the bottom end can/will hold before going. thanks
youll need a clutch
you can install the turbo and see how it goes though... if your only using it to pass cars then it might work for a while. but if your launching then yea, its gonna slip, bad.
good luck on this though, ill be very impressed if you can manage to build a turbo kit for 1200 [8D]how much boost are you thinking of running? just out of curiousity
you can install the turbo and see how it goes though... if your only using it to pass cars then it might work for a while. but if your launching then yea, its gonna slip, bad.good luck on this though, ill be very impressed if you can manage to build a turbo kit for 1200 [8D]how much boost are you thinking of running? just out of curiousity
ORIGINAL: didder
godspeed kits go for $1200 on ebay, the ss kits go for like $600, godspeed actually dont explod all over i hear. but hes still going to need a lot of other stuff the godspeed kit doesnt have
