Eddlebrock performer X kit
Ok a i have a 98 civic coupe ex with a stock d16y8 motor everyone says this is the most complete kit i can get and comes with some perty hi end parts. I need encouragement to buy this it is $3,500 shipped which is the best deal i can get it at please give me some oppinions and any alterations i may need to make.
here is a link to the pdf catalog its on page 3 http://www.edelbrock.com/sportcompac...008_sc_cat.pdf
unfortunatly its not on the website you suggested. Do you guys think it looks perty complete or do i need anyhing extra or be prepared to make any more pricy adjustments
I'd go for it if I were you. Once you become familiar with it, you'll be able to make a good custom turbo kit for cheap. Plus you dont have to deal with all the bull**** when it comes to gaskets, nuts, bolts, lines, and fabricating things for proper fitment. The best turbo kit i've seen around.
________
VenusGoddess
________
VenusGoddess
your going to need a **** load more stuff, y dont you do some research. your going to need to build your engine if u plan on hitting high numbers, you will need to chip your ecu or get a piggy back, some gauges, exhaust, clutch, all sorts of stuff. Also you will need to get it installed and tuned on a dyno.
