Extra injector?
Got a quote from a workshop on installing turbo kit
They mention that my D17 SOHC engine need addition 2 more injector, a stronger fuel pump. Just wondering, where are they going to install the two additional 2 injector? Felix |
RE: Extra injector?
well the stronger fuel pump i could see...but if u got bigger injectors that should do the trick...never heard of adding an injector.
RE: Extra injector?
They can't just add 2 injectors......somethin wrong with that picture!
Go get it checked out at a different garage. |
RE: Extra injector?
They do add injectors at times. They would be somewhere in the intake path(airflow). It is not as good as getting bigger injectors, but it does the trick(bandaid). However it is taking a step back(kind of like carburator) since the fuel is injected so far from the combustion chamber thus less efficient.
RE: Extra injector?
Seen an IM with spots for 8 injectors. Not 2 though, they would have te be up high near the plenum. That wouldnt make much sense
RE: Extra injector?
hell yeah you can just add 2 extra ones. thats a common setup with turbos. look at an FD rx-7, it has a secondary set of injectors, as do a lot of Supras. i believe they will set them up in the manifold somewhere that will disperse the fuel into the cylinders as even as possible. and with a d17, you WILL need a bigger fuel pump and definately some bigger/ or extra injectors.
RE: Extra injector?
Yes, I've seen cars with a secondary set of injectors (same number as the amount of cylinders), but never just a random number of extra injectors like 2.
RE: Extra injector?
http://www.kingmotorsports.com/produ...&vehicle=Civic
what about that one, I was thinking about getting that for my D17, along with a new fuel regulator, new fuel pump, new fuel rail I am going to run a T3 turbo |
RE: Extra injector?
ORIGINAL: 97CivicEX However it is taking a step back(kind of like carburator) since the fuel... |
RE: Extra injector?
ORIGINAL: Nail I3unny ORIGINAL: 97CivicEX However it is taking a step back(kind of like carburator) since the fuel... Oh and there are plenty of carb to EFI conversion kits out there, so with the right knowledge and will power you can convert back and forth with not much effort. I would have to disagree on the weight. I live in Cali where the smog regulations are probably the most strict within the US. The emissions hardware needed on carb-ed vehicles will all add up to more than the weight of the injector system. |
