Extra injector?
Got a quote from a workshop on installing turbo kit
They mention that my D17 SOHC engine need addition 2 more injector, a stronger fuel pump. Just wondering, where are they going to install the two additional 2 injector?
Felix
Felix
They do add injectors at times. They would be somewhere in the intake path(airflow). It is not as good as getting bigger injectors, but it does the trick(bandaid). However it is taking a step back(kind of like carburator) since the fuel is injected so far from the combustion chamber thus less efficient.
hell yeah you can just add 2 extra ones. thats a common setup with turbos. look at an FD rx-7, it has a secondary set of injectors, as do a lot of Supras. i believe they will set them up in the manifold somewhere that will disperse the fuel into the cylinders as even as possible. and with a d17, you WILL need a bigger fuel pump and definately some bigger/ or extra injectors.
http://www.kingmotorsports.com/produ...&vehicle=Civic
what about that one, I was thinking about getting that for my D17, along with a new fuel regulator, new fuel pump, new fuel rail
I am going to run a T3 turbo
ORIGINAL: 97CivicEX
However it is taking a step back(kind of like carburator) since the fuel...
ORIGINAL: Nail I3unny
a carb isnt neccisarily a step backwards, theyre much more simple than feul injection and weigh TONS less...and its (comparitavely) easy to convert EFI to carburation (vice versa...dont try...even pros have a tough time with that one)
ORIGINAL: 97CivicEX
Oh and there are plenty of carb to EFI conversion kits out there, so with the right knowledge and will power you can convert back and forth with not much effort.
I would have to disagree on the weight. I live in Cali where the smog regulations are probably the most strict within the US. The emissions hardware needed on carb-ed vehicles will all add up to more than the weight of the injector system.
