fmu&injectors
Old Sep 29, 2009 | 05:57 PM
unclen8's Avatar
Default fmu&injectors
heres another question, i see people use fmus. some of them tell you they are using larger injectors others dont. so, if use an fmu, will i have to use larger injectors or can i run the stock ones?
Old Sep 29, 2009 | 06:20 PM
croninc's Avatar
fmus are retarded out-dated fuel management systems. We have the technology to properly chip an ecu and do it the right way. Stay away from fmus. BTW what are you turboing?
Old Sep 29, 2009 | 10:17 PM
GReddy_Civic's Avatar
Snail'n Admin
anytime you turbo, you need more fuel. hence you need a way to get the fuel. The most common way is bigger injectors. The edelbrock kit used to include an intake manifold with ports for an extra set of injectors. And yea, FMUs are the gay. pay 140$ or whatever it is for a chipped ECU with crome or uberdata or something
Old Sep 30, 2009 | 01:13 PM
hamorhead's Avatar
just so the OP knows you should NOT just buy a chipped ecu and run boost off of it. It comes with a basemap to get you to a tuner for it to be properly tuned by a professional.
Old Sep 30, 2009 | 06:03 PM
Snail'n Admin
^correct. and usually the basemaps suck. Mine was terrible. I drove 31 miles to my tuners and my plugs were BLACK from runnin so rich.
Old Oct 2, 2009 | 08:12 AM
unclen8's Avatar
i am turbocharging a 95 ex (d16z6 v-tec)
Old Oct 3, 2009 | 06:08 PM
FlipHKD720's Avatar
www.phearable.net
since you're already at OBD1 get a socketed/chipped p28 from phearable and get it tuned, soooo much better than an FMU.
And cheap injectors that will support a low-level boost project at DSM blue-top 450cc injectors, with a resistor box they can be had for well under $100
Old Oct 5, 2009 | 04:31 PM
unclen8's Avatar
thanks for all the input, looks like i may be able to turbo my car under my budget, if i can find that flange from my other post that is. gotta get better pictures up in a hurry
Skrapdoggydog
Aug 15, 2006 04:21 PM
mac3a
May 5, 2006 08:44 PM
Chimera02EX
May 2, 2006 04:03 PM
fast93civic
12
Apr 29, 2006 12:30 AM
97exhonda
Nov 16, 2005 08:23 PM
