HELP!!! fast
Old Jul 31, 2006 | 09:57 PM
alyssa4303's Avatar
Default HELP!!! fast
does anyone know if a 1g eclipse td05h eclipse will fit my 2003 civic ex ?? helpppp thanks <3333
Old Jul 31, 2006 | 09:58 PM
alyssa4303's Avatar
Default RE: HELP!!! fast
meant to write turbo eclipse turbo ooopps blonde moment
Old Aug 1, 2006 | 12:04 AM
red2000Si's Avatar
Im going to assume your talking about a mitsubishi tdo5h turbo. I actually just bought one, and to answer your question, I believe if you have the right manifold for your motor, with the right flange for the turbo, it should fit just fine. Hope this helps! Nice blonde moment by the way
Old Aug 1, 2006 | 12:07 AM
96civic285whp's Avatar
^ +1 it should fit fine just make sure your manifold will work with it.
Old Aug 1, 2006 | 09:09 AM
Like these guys said, search around and see if you can find an "adaptor plate" for that application.
I'll pm you a site or two that might help your search as well..
Old Aug 2, 2006 | 12:14 AM
VTECivic95's Avatar
from what my friend tells me from research on his forum, most eclipse turbo manifolds bolt right up to some honda motors. hes got an F22A1 in his '92 CB7 and the eclipse manifold bolts right up EXCEPT you hafta drill one more hole in the manifold for a direct bolt up. but i dont know what motor is in your 2003 cause im more familiar with the older models but some honda motors it is a 90% direct bolt on.
Old Aug 2, 2006 | 10:33 AM
riceburner700's Avatar
just need a manifold made for it or an adapter flange
hondaisforamericatoo
Jun 12, 2005 05:29 PM
JIZZO
Apr 11, 2005 08:52 AM
89civiclx
Feb 10, 2005 12:50 PM
the_reptilian
Jan 16, 2005 05:15 PM
