how much boost is safe
Old Jan 3, 2007 | 04:16 PM
mugen23's Avatar
Default how much boost is safe
sohc motor is it safe to run -10 psi witha professional tunning it , but it wont be on a dyno just a tunner guy and all his stuff hooked up to the engine tunning it , it should be safe right, or is 8 psi all i can go
Old Jan 3, 2007 | 04:25 PM
INJENalltheway's Avatar
Default RE: how much boost is safe
There is a sticky at the top of the turbo nitrous thread that addresses this.
https://www.hondacivicforum.com/m_151707/tm.htm
Old Jan 3, 2007 | 06:12 PM
finalimpact's Avatar
took the words right out of my fingers..........basically the post is telling you to not base it on psi and base it on a certaint additional power level, in this case 50%. reason being is that all turbo's supply different air flow rates(cfm). for instance a t25 at 10psi will not flow nearly as much air as a t3 at 10psi generally speaking. for the most part sohc 1.6l engines have been known to make 200whp on stock internals and a good tune reliably.
Old Jan 3, 2007 | 09:04 PM
riceburner700's Avatar
so many guys have yelled in my face because they think d-series cant make over 150hp
Old Jan 3, 2007 | 09:07 PM
ej6buddy's Avatar
lets see.... um, none. lol
Old Jan 3, 2007 | 10:02 PM
devney's Avatar
Why would they yell in your face? D-series can easily make over 150...very easily. And I'll add that it can be very reliable also.
Old Jan 4, 2007 | 08:29 AM
Mr Mobsta Man's Avatar
ORIGINAL: devney
Because they think that nawz stickers are a safer way to add hp
Old Jan 4, 2007 | 09:14 AM
ORIGINAL: riceburner700
morons, haha. I'll have a dyno sheet to prove that wrong fairly soon. And that dyno reading will have been taken after 7 months of boosting
Old Jan 4, 2007 | 03:20 PM
Kedawei's Avatar
ORIGINAL: devney
Why
Because they got suckered into buying a B series.
Old Jan 4, 2007 | 10:04 PM
let me dig up the link.. its pretty funny
http://www.highaltitudeimports.com/t...l-this-be.html
