Internal Wastegate/Manifold
Old Sep 30, 2007 | 04:17 PM
bcrichguitars's Avatar
Default RE: Internal Wastegate/Manifold
Ya you could do that but why not just buy a hf manifold without the external wastegate port?
The HF manifolds aren't supposed to have a external wastegate flange. Just get a regular HF manifold.
Old Sep 30, 2007 | 08:44 PM
FadedShadow01's Avatar
i can't find one with out the port on ebay
Old Sep 30, 2007 | 08:47 PM
SE_2_EG's Avatar
I have a kit for sale in the classified section
Old Sep 30, 2007 | 08:49 PM
This is the first thing that came up when I typed HF Manifold http://cgi.ebay.com/ebaymotors/89-90...ayphotohosting
It's those ones. Came on CRX's and Civics.
Old Sep 30, 2007 | 09:33 PM
hey SE_2_EG u get my pm jw?
Old Oct 1, 2007 | 07:32 AM
also what kinda fmu( ration )and injectors should i get?
Old Oct 1, 2007 | 08:12 AM
ORIGINAL: FadedShadow01
i dont know exactly wat it came off of but its small an im gonna try to get a pic of it soon.
-Turbo pics-
http://i75.photobucket.com/albums/i3...n/100_6738.jpg
http://i75.photobucket.com/albums/i3...n/100_6737.jpg
http://i75.photobucket.com/albums/i3...n/100_6736.jpg
Old Oct 1, 2007 | 08:32 AM
FlipHKD720's Avatar
Old Oct 1, 2007 | 08:01 PM
WhiteBoyzRacing's Avatar
you can get them from ur local junkyard. prolly cheaper then u can find them on ebay.
Old Oct 1, 2007 | 08:04 PM
ORIGINAL: FlipHKD720
ORIGINAL: WhiteBoyzRacing
im using a t25 off of an eclipse, i have the adapter pl8 that mounts the turbo upto the hf mani, hks ssqv bov, fuelpressure reg, dsm 450cc injectors, chippd but not tuned, the setup works good, the t25 spools up quick and works well with the d motor i dont see any lagg at all. but im also only running like 7psi lol. just make sure you replace the gasket between the mnai and adapter its the crush one for the hf mani, itll leak if you try to reuse it. i found out the hard way lol
i think T25's are internally gated 8 psi, could be wrong thouhg
and as for that ebay like to that manifold, it might work, but HF's can be had for like $40 (atleast mine was). Just look around and you'll find deals. And you know its gonna be tough, so theres no worry there.
i think they are also, but im leaking from between the mani and the turbo, bad crush gasket, and nobody had it in stock so i had to order the dang thing.
