Junkyard turbocharger
Old Aug 14, 2005 | 12:27 PM
StifflersMom's Avatar
Cat Fuсker
Default Junkyard turbocharger
Today I went to the junkyard to get me some teggy parts, found all that I needed, but also found a Benz of some sort (crashed badly, can't tell WTF it is) but there's a turbo sitting in it...I wonder if I should go for it or not...they said they'll take $100 for it
Old Aug 14, 2005 | 12:43 PM
ngoti 8tor's Avatar
Default RE: Junkyard turbocharger
Go for it! If you don't use it, you can always try to sell it on here or on eBay.
Old Aug 14, 2005 | 01:59 PM
Cat Fuсker
I'll try to get the sucker off next week...anyone know how to check it for being useable?
Old Aug 14, 2005 | 02:31 PM
ngoti 8tor's Avatar
I think the most important thing to check is if there's any play on the shaft.
Old Aug 14, 2005 | 03:37 PM
fast93civic's Avatar
check for oil leaks if possible, look for cracked or damaged blades, and housing
Old Aug 14, 2005 | 03:57 PM
Cat Fuсker
Oil lines are missing...should I just pour oil into it?
Old Aug 14, 2005 | 06:34 PM
what i would do, is yea, pour a bit of oil in to it, and with your finger turn the blades over a little bit, then check for any oil residue.
Old Aug 14, 2005 | 06:48 PM
Street Sniper's Avatar
Umm, I dont' think you can juts pour oil in it since there shold be fittings for the oil lines and you can't exactly just put a funnel to them. Just inspect it really well when you get it off. There shouldn't be any runs of oil on it, shaft play is the first sign of wear. Like Fast93 said, check for cracked blades and/or cracks in the housing. Try to get a look at what kind of turbo it is and then look it up.
Go over to HomeMadeTurbo, I think they have an article on what to look for when pulling a turbo out of the junkyard.
Old Aug 14, 2005 | 07:25 PM
FD_Sauce's Avatar
Sorry About That Fellas
Old Aug 14, 2005 | 07:53 PM
already stated ^
