ls or b16 n/a
which would be better, a b18 ls with turbo non v-tech?
or a b16 n/a which should i get, i am still debating on which engine to get someone help me out |
RE: ls or b16 n/a
Between the two, I'd go with an LS turbo. But overall I still say get a GSR and boost that.
RE: ls or b16 n/a
ORIGINAL: Kappa22 Between the two, I'd go with an LS turbo. But overall I still say get a GSR and boost that. |
RE: ls or b16 n/a
its the easiest to build from, especially with FI. do you expect the best engine to be different in each question, when the questions are mostly the same?
RE: ls or b16 n/a
well an ls swap is going to be cheaper and could use money saved on boost, and its vtec, v-tech is a phone manufacture
RE: ls or b16 n/a
do an LS vtec...thatd be sick. LS block with a B16A head. good idea.
RE: ls or b16 n/a
ORIGINAL: Nail I3unny do an LS vtec...thatd be sick. LS block with a B16A head. good idea. |
RE: ls or b16 n/a
[:'(] LS-VTEC [:'(] Get a B20 from a CRV and put a VTEC head on that... now here I was erally kidding
RE: ls or b16 n/a
ORIGINAL: sacicons do you expect the best engine to be different in each question, when the questions are mostly the same? And about the LS-VTEC, stay away from it unless Mugen is building it for you. 90% of the time they go down from serious failure of oil pressure to the cams, because 90% of the people who build them don't know how to run external oil lines that will actually be effective. CR-VTECs have even more problems... |
RE: ls or b16 n/a
awww comon, cylinder walk is fun!
