max hp-d16y8????
Old Oct 11, 2006 | 01:26 PM
thebadgator87's Avatar
Default max hp-d16y8????
whats the most horsepower anybody has got out of the d16y8??? and how much boost were they pushing???
thanks kev
Old Oct 11, 2006 | 08:44 PM
theonecalledtodd's Avatar
Default RE: max hp-d16y8????
well honestly, boost isnt whats important becuase different turbos displace a diferent amount of air per lb. of boost. But to answer the first question i saw a dyno sheet for a d16 pushing around 430Hp. Of course he had a total build up.
Old Oct 11, 2006 | 08:57 PM
Marty's Avatar
I seen a stock D16Z6 at 300whp
Old Oct 11, 2006 | 09:04 PM
what do u mean by total build up? like internals
ORIGINAL: theonecalledtodd
Old Oct 11, 2006 | 09:10 PM
mybrokenblinker's Avatar
well if you're looking for a simple build. SovietX...i dont remember the rest of his name posted his dyno and videos of running a stock y8 with 7 pounds of boost making 210 horsepower
Old Oct 11, 2006 | 10:04 PM
Kedawei's Avatar
The most I've seen is 450-500whp, though I've of heard estimates of 550 being possible on stock sleeves. There's a team claiming to make 375 on a completely stock block z6. I don't know about that one though.
Old Oct 12, 2006 | 06:57 PM
yamahaSHO's Avatar
Generally, boost is boost. The major factor that would have one turbo be less powerfull than another at the same boost would be it efficiency in relation to heat. If you heat up the air, you're going to get less power from the same boost if it were cooler.
Boost is just a measurement of the restriction in your intake. If you start making modifications to your intake tract, bigger displacement, different cams, etc, your boost readings could be lower, however, you could be pushing the same, or more power.
Old Oct 12, 2006 | 11:56 PM
SovXietday's Avatar
ORIGINAL: Marty
Guy who lives 30 minutes away from me put down 380whp on a stock Z6 with race gas and a GT2871RS. Absolutely rediculous.
Most power I've ever seen specifically made from the Y8 was 386ish. I think another guy put down 405whp on a Y8 block and Z6 head, but I'm not 100% sure.
I personally am shooting for the 400+ mark, but right now I'm making 210whp 167wtq at 7psi on a 100% stock D16Y8.
troublesome222
Apr 15, 2006 02:38 AM
XCM828
Feb 17, 2005 10:40 PM
zaidomar
Nov 17, 2004 01:06 PM
