multiple turbos?
Old Jun 19, 2009 | 06:19 PM
kylea24's Avatar
That would be a sequential twin setup. Some sequentials use two different sized turbos (a small one that spools up quick and a large one that spools up slower for more all-around power) while others use two identical snails; one creates an initial amount of boost, and the other compresses the air even further.
The alternative style of twins is a parallel setup like I'll be doing; two identical turbos separate from one another where each turbo uses exhaust flow from half the cylinders.
Like I said, though... with an inline configuration, you might as well just get a hybrid turbo like a t3/t4; you'll get the same result.
wow good info there but you can have a very good result with a TT in a inline configuration as well (not nessisarlly honda I-4's) but more of the inline 6's just look at the 2jz and the Rb20's
Old Jun 19, 2009 | 06:24 PM
There's exceptions to every rule. But I'd like to point out what most people with 2jz-gte's and rb26dett's (the RB20det never came with a twin-turbo setup ) usually do. They scrap the stock twin setup and switch to a single huge turbo.
For a 1.6, 1.8, 2.0, or 2.2 liter inline four, I wouldn't recommend any form of twin turbos; there's a difference in exhaust flow among the 1.6l D16, 2.6l RB, and 3l 2jz
Old Jun 19, 2009 | 07:47 PM
kylea24's Avatar
yep caught me on that one, i have seen many gt-r's with a single turbo set-up but not so many 2jz's.
TT and 4 banger's just dont go good together, go simple with one!
TGriffin
Jun 21, 2010 09:58 AM
longdrive352
Nov 2, 2009 05:07 PM
4BiddenDx
Oct 2, 2007 03:10 PM
SpeedRacer_87
Jul 25, 2007 05:10 PM
benstalk
Jun 4, 2005 11:13 AM
