for my turbo project, i know i need these, but do i need these?
alright guys I'm oh so close to having a turbo in my car. i have a 2000 integra ls. this IS MY DAILY DRIVER and i plan on keeping it @ 7 psi
heres my turbo kit: drag exhaust mani turbonetics t3/t4 turbo tial 38mm wastegate blitz blow off valve front mount intercooler drag boost dependent FMU fuel regulator MAP sensor bypass valve assembly w/blox MAP bypass drag high pressure/high volume inline fuel pump all the piping, etc. I know I need/plan to get act clutch arp headstuds new head gasket new timing belt ngk spark plugs gauges turbo timer new camshafts hondata s300 w/dyno tune should I get.... boost controler bigger injectors cooler radiator walbro fuel pump (or no since the kit comes with the inline fuel pump) springs & retainers i wont need low compression pistons since i dont have plans on going much above 7 psi right? anything else i didnt think of? |
RE: for my turbo project, i know i need these, but do i need these?
as far as i cna see you are on the right track but I would suggest that you get this stuff also
bigger injectors-if it doesnt come in the kit cooler radiator-yes to keep ur engine cooler seeing there is going to be so much heat under hood with the turbo walbro fuel pump-not really nessiceray but its a plus springs & retainers-to help out with the cam if u put them on. if u go aftermarket cams you will need them. what kit did u get or was it a piece together kit. |
kit is a rev hard generation III kit. it is $3,000 and you can get the clutch from them too for $350, rc 310cc injectors for $310. are those the right size injectors?
also, should I get a hood with a hood scoop and some vented fenders too to help with cooling? |
is this the info for ur kit our along these lines:
NEW! Stage: 2 Use: Street/Track Part #: RHSTGII MSRP: $3,599.00 (New Pricing) This kit will be Pending CARB legality http://revhard.com/images/spacer.gif Boost Level: 7 PSI Injector Size: Stock Horsepower/Torque: +120 / 285 ft/lbs http://revhard.com/images/spacer.gif [ul][*]Rev Hard Cast Iron Manifold[*]Rev Hard T3/T04E Hybrid Turbo(eff. to 450hp)[*]Rev Hard Intercooler (28x6.5x3)[*]Tial Wastegate (7 PSI)[*]Rev Hard Blow-Off Valve[*]2.25" Mandrel Bent Piping[*]2.5" Downpipe[*]Billet Map Diffuser (Check Valve)[*]High Volume Fuel Pump[*]Silicone Hoses and Clamps[*]Steel Braided -3 Oil Line[*]Oil Return Line[*]High Pressure Fuel Line[*]High Pressure Silicone Hoses[*]Necessary Vacuum Lines[*]Rev Hard FMU[*]Necessary Vacuum Tee's[/ul] http://revhard.com/images/spacer.gif Optional Upgrades http://revhard.com/images/spacer.gif [ul][*]2.5" Aluminum Upper Charge Pipe for 94-01 Integras / 92-00 Civics[*]Ball Bearing Turbo Upgrade[*]Tubular Manifold Upgrade[/ul] http://revhard.com/images/spacer.gif Available Applications http://revhard.com/images/spacer.gif 00+ Honda S2000 Scion XB and TC Coming Soon! 02+ Lancer Evo 8 92-00 Civic (D Series Motors) 92-00 Civic Hybrid (B-Series H22 VTEC) 94-01 Integra (All) 97-01 Honda Prelude 88-91 Civic/CRX (D16/ZC) 88-91 Civic/CRX (B Series Motors) For all 88-91 Civic / CRX only - Requires removal of air conditioning, smaller radiator, cutting the subframe, and relocating or use of a smaller battery. 90-93 Integra (ALL) - Requires removal of air conditioning http://revhard.com/images/spacer.gif Please call us for custom applications. cause this is the only thing really rev hard has for the b-serries motors.http://revhard.com/images/spacer_gray.gif |
oh poop... i meant drag! i was going to go with the rev hard before i found this one.. yea its a drag kit... www.dragturbokits.com
You might wanna get the injectors and fuel pump. I dont know much about drag kits butit cant hurt. Oil lines? Dunno, seems like you should be doin more research instead of shoppin
oil lines? what are you even talking about?
you gotta have a way to cool the turbo, whether it be oil or water, and im assuming the t3/t4 is oil. You have to have a way to cycle the oil. Otherwise youll ruin the turbo. I suggest you do A LOT more research before you go and blow up your engine. Or if you want, run it without oil lines...let me know how it goes ::thumbup::
ORIGINAL: 00IntegraLS oil lines? what are you even talking about? |
ORIGINAL: gsumano ORIGINAL: 00IntegraLS oil lines? what are you even talking about? |
