new to boost need some help, buildin nasty eg
Old Apr 25, 2008 | 11:57 AM
nastyegb18's Avatar
Default new to boost need some help, buildin nasty eg
i currently plan on building a b18 series honda engine with a b16 gsr head and swapping it into a 1992 honda civic hatchback. i am goin to have my engine sent to laskey racing for all of the following to be done.
Benson sleeved block
Benson balanced and micropolished crank
CP pistons and rings (prolly 9:1, possibly 9:7:1 im not sure what to use)
Pauter rods
ACL bearings
OEM (TypeR) oil pump
Lower gasket set
Blueprint and assembly
Boxing, return shipping and insurance
all this crap is gonna be crazy expensive like 3500 just for that but its guarenteed to withstand 50lbs of boost, and money is not gonna be an issue im gonna be saving up and building over a year or so
i used an online horsepower from boost calculator and figured around 200hp with 30lbs of boost will produce 600 hp, if yall wouldnt mind could you tell me all what else im gonna need to get, injector size, fuel pump size, cams, tuning/ecu? im pretty sure im gonna have to get a aftermarket crank too.
also i am probably gonna run around 10lbs of boost normally and just crank it up for the track, would i be able to do this or am i gonna have to have it tuned to run a certain psi all the time?[/align]
Old Apr 25, 2008 | 01:20 PM
inthezoneac's Avatar
Default RE: new to boost need some help, buildin nasty eg
ORIGINAL: nastyegb18
Pauter rods
ACL bearings
Lower gasket set
if you're going to spend $3500 for all that why not just get a built engine for that price?
Old Apr 25, 2008 | 02:56 PM
GReddy_Civic's Avatar
Snail'n Admin
ORIGINAL: inthezoneac
Are you serious, or just that retarded?
Old Apr 25, 2008 | 04:28 PM
civicduty96's Avatar
theres no such thing as a b16 gsr.... a gsr is a b18 integra motor ....
Old Apr 25, 2008 | 08:44 PM
nastyegb18's Avatar
ORIGINAL: civicduty96
have you ever heard of a poor man's gsr
look it up
and inthezoneac that is whats happenin, all i have to do is send them the b18 block and they build it into a race engine
Old Apr 25, 2008 | 09:15 PM
gsumano's Avatar
What he means, is adding a gsr head to a b16 block.
Old Apr 25, 2008 | 09:26 PM
Live_4it's Avatar
Good luck, your going to have to really know your stuff if your aim is going to be that much power.
Old Apr 26, 2008 | 04:42 AM
nastyegb18's Avatar
thats the problem i dont know my stuff...ive been reading and reading, but still id like some imput from a couple people who have actually done it, and im really only looking for 400whp 600 is way too much....well not really but you get my drift
Old Apr 26, 2008 | 08:24 AM
I thought the b16 head outflowed the b18c head? I could be wrong though. And just so you know, you're going to have some serious traction issues (even with "only" 400hp).
Also, as a side note, it doesn't matter how much boost you're making. 10 psi on a 14b is different than 10 psi on a t3/t4. What matters is how much power you're making.
Old Apr 26, 2008 | 10:19 AM
Mr Mobsta Man's Avatar
Please post the carnage pictures of the car after you wreck it.
