Nitrous
Old Oct 16, 2007 | 09:40 AM
Mr Mobsta Man's Avatar
Default RE: Nitrous
I don't know about d17's but d16's have forged cranks so just get it balanced I don't think you need it replaced. Remember with high compression and nitrous you are gonna have to run race gas... or convert to E85 which is 110octane.
Old Oct 16, 2007 | 11:26 AM
D17Punk's Avatar
Default RE: Nitrous
Will i have to run race gas even though i wont be using the nitrous alot? and just because of high compression i will need it? would octane booster work? i dont think anyplace around where i live sells 110
Old Oct 16, 2007 | 11:27 AM
D17Punk's Avatar
Default RE: Nitrous
Also if its my daily driver too i will always have to use the 110?
Old Oct 16, 2007 | 11:42 AM
Default RE: Nitrous
Depends on your compression ratio, I think people running like 12:1 or 13:1 are okay with premium pump gas (91-93+ depending on where you live) but defiantly having high compressionAND using nitrous then you will have toHAVEto use racegas.
Old Oct 16, 2007 | 03:08 PM
Pete's Avatar
Default RE: Nitrous
Are you going to be converting your fuel system over too? You dont wanna run dry nitrous, its just stupid. Youre fuel system is returnless, and wet nitrous requires a returning fuel system
Old Oct 16, 2007 | 05:27 PM
desert2007's Avatar
Default RE: Nitrous
ALOT of good info in here, definatly will be paying attention to this one as i was thinking of adding some Nitrous to my 96 d16. Whats with the returning fuel system, im kinda lost at that part.
Eric.
Old Oct 16, 2007 | 05:28 PM
D17Punk's Avatar
Default RE: Nitrous
Before i even do the nitrous, i will be doing an intake manifold swap, and i will also be putting in the high pressure fuel pump most likely, its a thread on here in the DIY section.
Old Oct 17, 2007 | 03:52 AM
D17Punk's Avatar
Default RE: Nitrous
I own a wet kit as of right now i have everything but the window switch and WOT switch, ii also want to get the auto bottle opener so i dont have to get into my trunk all the time.
Old Oct 17, 2007 | 10:49 AM
Default RE: Nitrous
You know you're gonna need some sort of ecu management to run a different fuel pump correct?
ORIGINAL: desert2007
Eric.
Your car has a return fuel system, it means that there is a fuel line going both from the gas tank to the engine then back to the gas tank again. It is a good thing for nitrous/turbo. The original poster has a D17 and they have a returnless fuel system meaning there is just a fuel line going from the gas tank to the engine.= having to convert to return system to run nitrous safely... not worth it. IMO the only work you should put into a d17 is pulling it out to put in a k20.
Old Oct 17, 2007 | 12:08 PM
D17Punk's Avatar
Default RE: Nitrous
nah it isnt that hard to put in a return fuel line system look at the manifold swap i will be doing that when summer rolls around.
