nitrous question
i used to get my bottle filled at a local performance shop and they always took an hour to fill my lil 10oz bottle because they said they had to freeze it, but this new place i go to ( its a desiel repair shop) just takes in the back and 5 min late voila finished whats the deal with freezing the bottle.
RE: nitrous question
nitrous bottles used to be frozen(some places still do) so the nitrous turns to a liquid, and fills the bottle completely, but now they use compressed air to pump the gas into the bottle i believe http://www.holley.com/data/products/...nd%20Scale.JPG
they use something like that to refill now |
I think you don't get as much nitrous doing the quicker method. I'm not talking extreme loss.It's probably not even noticeable.
Think of it scientifically: When molecules are colder, they move slower and take up less space. The opposite it true as well, when molecules are warmer, they move quicker and take up more space. Here's an easy example: Fill a balloon with air. Now, put the inflated balloon in a freezer. Give it a little bit of time and then look at it. It will look semi deflated. That's because the molecules got colder and slowed down in the colder enviroment. Air was never lost, just chilled. Remove it from the freezer and you will see it inflate back to normal. [Note: Water and a few other molecules don't obey this principle, but that's another can of worms.] Now try this: (If you live in a cold place like Wisconsin or have a walk-in freezer, it's easier to do.) Pump a balloon full of cold air (don't blow it up with your mouth) with a pump and do this in a cold environment. Once it's filled, bring the inflated balloon into a warmer place, preferably warmer than room temperature. Once the air inside the balloon heats up, the balloon will begin to expand. It may even pop due to the pressure. (This is also why aerosol cans have a maximum heat exposure warning) So, when you freeze the nitrous bottle, it creates a colder environment, thus allowing more nitrous to fill the space. I hope this helps!:D p.s. I hope the place that does it quicker charges less. You get less and they work less. |
Oh, I almost forgot. When they refill it, make sure they let the gauge measure the pressure for a bit. I once worked at a party supply store. I was in charge of refilling helium tanks. I learned that if you fill a tank until the gauge says it's full, then close everything off immediately, the tank won't be totally full. You have to wait 2-3 minutes for the gauge to acurately measure the psi. The guage reading settles much slower than a standard bathroom scale settles.
Then again, I used crappy analog gauges. We didn't have fancy digital gauges. |
thanks for all your help. actualy the faster place changes more but i moved away from theother place so now its an hour away and i only get it filled therewhen ivisit my parents. butthis is only place that i know that can fillmy bottle they charged me$10($1 and oz)i dont think they have a set price because i didnt get a reciet or anything.
ORIGINAL: danomatic93 Oh, I almost forgot. When they refill it, make sure they let the gauge measure the pressure for a bit. I once worked at a party supply store. I was in charge of refilling helium tanks. I learned that if you fill a tank until the gauge says it's full, then close everything off immediately, the tank won't be totally full. You have to wait 2-3 minutes for the gauge to acurately measure the psi. The guage reading settles much slower than a standard bathroom scale settles. Then again, I used crappy analog gauges. We didn't have fancy digital gauges. |
Well, helium tanks don't have heater heads or whatever. Sounds cool, but gas weighs near to nothing. Whatever.
Well nitrous is a liquid at room temp I think so that might have something to do with it. lol
