ok, stock engine..
Old Nov 24, 2007 | 06:30 AM
Redline25's Avatar
Default ok, stock engine..
2000 Ex coupe.
stock performance.
and 4000$.
What I need to know is do I upgrade to Vtec, then turbo it for the most HP? Or do I do something else? I have no idea with the turbo thing.
My engine is the stock 1.6L 4cyl
What in your opinion would be the best way to go for maximum horses?
oh and if you know any websites with some cheaper than 2800$ turbos, let me know lol.
Old Nov 24, 2007 | 07:07 AM
my05civic's Avatar
Default RE: ok, stock engine..
read the forum for topics regarding the d16y8, that's the engine you have. you need to do A LOT of research before you even consider turbo, because it's not exactly as simple as putting on a intake. most of the engine work that you'll do is so you can run more boost; you CAN turbo the stock engine without building the stock internals, but you'll then be limited to lower boost levels. the vtec upgrade that you speak of bears no purpose, since you ALREADY have vtec.
(from wikipedia)
D16Y8 Also available in New Zealand under the code D16Y6 [ul][*]VTEC[/ul] [ul][*]Found in [ul][*]1997-1998 Honda Civic EX Sedan[*]1996-1998 Honda Civic EX Coupe[*]1996-2000 Honda Civic EX (USDM)[*]1996-2000 Honda Civic SI (Canada Only)[*]1996-2000 Acura 1.6EL (Canada Only)[*]1996-1997 Honda del Sol Si [ul][*]Displacement: 1590 cm³[*]Bore and Stroke: 75 mm X 90 mm[*]Compression: 9.6:1 Piston Code:P2P[*]D16Y8 1.6 16V SOHC VTEC-II PGM-FI 1590[*]126 hp@5900 rpm 108tq@4800 rpm[*]Head Code: P2P[*]VTEC crossover: 5300 rpm[*]Redline 7200 rpm[/ul] [/ul] [/ul]If you want a cheaper turbo setup, you'll need to piece it together yourself. Turbo-kits.com and dezod.com (the sites i assume you went to), have kits that are overpriced. however, considering that you know nothing about turboing a car, you'll need to do a lot of research first.
good luck man. you have a lot of work ahead of you
Old Nov 27, 2007 | 09:13 PM
Littlehag's Avatar
ORIGINAL: my05civic
(from wikipedia)
[ul][*]VTEC[/ul]
[ul][*]Found in
[ul][*]Displacement: 1590 cm³[*]Bore and Stroke: 75 mm X 90 mm[*]Compression: 9.6:1 Piston Code:P2P[*]D16Y8 1.6 16V SOHC VTEC-II PGM-FI 1590[*]126 hp@5900 rpm 108tq@4800 rpm[*]Head Code: P2P[*]VTEC crossover: 5300 rpm[*]Redline 7200 rpm[/ul][/ul][/ul]
Just a little fact, wikipedia is a public site that anyone can get on and post anything they want. Not saying that post has anything wrong with it. Just advising, not everything you read on there is true. I found that out the hard way.
Old Nov 29, 2007 | 06:08 PM
johnny's Avatar
He has a D16Y7.
No VTEC.
Old Nov 29, 2007 | 09:03 PM
FlipHKD720's Avatar
ORIGINAL: johnny
He has a D16Y7.
No VTEC.
2000 EX with a y7? You SHOULD have VTEC unless your car is from Canada or something
but with $4000 you might be able to do a mild build, but at the very least a super nice turbo setup. As for more info about that, read the stickies.
Old Nov 30, 2007 | 06:46 PM
johnny's Avatar
ORIGINAL: Redline25
2000 Ex coupe.
stock performance.
and 4000$.
He should....
Old Nov 30, 2007 | 07:09 PM
95civic1.6l's Avatar
he should have a v-tec. Don't all the EX's have v-tec's?
Old Nov 30, 2007 | 09:21 PM
johnny's Avatar
The Canadian EX is D16Y7 and the SI is D16Y8
Old Dec 1, 2007 | 09:23 AM
civicfastfast's Avatar
I got a 99 ex coupe and its vtec
Old Dec 1, 2007 | 10:04 PM
didder's Avatar
ORIGINAL: johnny
canada sucks
