Pre Turbo Install
RE: Pre Turbo Install
ORIGINAL: djburn
I will be installing a turbo within the next 45 days, I was wondering if any damage wouldhappen if I installed an FMU early.
Don't install it, sell it and get real engine management like Crome, Uberdata, Hondata, etc..
ORIGINAL: djburn
So, the installation of a fuel pressure regulator will cause damage.
Besides, you said FMU, not FPR Which one are you wanting to install?
....even boosted, you can run the stock FPR and it will be a lot more efficient/reliable than aftermarket ones. You need spend a healthy chunk of change to get a good solid FPR, and imo, thats money wasted when the stocker is perfectly fine
I apologize for the mix up, I was talking about the FPR. I do plan to run Hondata, in the nest week I will be installing a y8 mani on my y7. For the hondata should I upgrade to a P28? And if so should I change injectors.
Read through the following link, then if you have more specific questions, we'll be more than happy to help.
https://www.hondacivicforum.com/m_400322/tm.htm
