s300 boost control or avc-r?
Old May 3, 2008 | 04:04 PM
didder's Avatar
Default s300 boost control or avc-r?
im really really really really stuck on this, i dont want to blow the 800 for a hondata s300 ecu, but it has full throttle shift! and boost control so its screaming my name...
but the avc-r is half the price or more and only missing the full throttle shift (which is totally a downside to me)
question is, how good is hondata's boost controller setup vs an avc-r?
Old May 3, 2008 | 07:27 PM
gsumano's Avatar
Default RE: s300 boost control or avc-r?
ORIGINAL: didder
What's the full throttle shift feature? Is that similar to the avc-r option that allows you to control the boost level depending on which gear you are?
Anyways, I vote for the avc-r because it looks cooler Oh, take a look honda tech classifield because I bought an used avc-r two weeks ago for $180
Old May 3, 2008 | 08:38 PM
Mr Mobsta Man's Avatar
Full throttle shift isa rev limiter that lets you shift gears without lettingoff thethrottle.
Honestly, both are fine choices but I would go with the hondata.
Old May 4, 2008 | 11:34 AM
GReddy_Civic's Avatar
Snail'n Admin
boost by rpm is win
Old May 4, 2008 | 07:13 PM
civicduty96's Avatar
the hondata s300 i think is one of the best piggybacks you can get.... if you use a ecu out of a auto trans you dont need to add anything to the board..... it hooks up to the tourque converter lockup output... otherwise you need a 220 ohm resistor, a 330 ohm.a diode and 2 transistors ....then a GM boost selinoid and your good to go... i put mine in myself and it wasn't that bad.....
it's hitting the dyno on the 13th i'll let you know how easy it is to tune
Old May 5, 2008 | 05:34 AM
Hondata isn't a piggyback.
Old May 5, 2008 | 06:14 PM
SovXietday's Avatar
^ Technically it is. A very advanced one though. I prefer to call it an EMS.
Go with the Hondata. You have full throttle shift regardless of which one you pick, Hondata is much much more than just a boost controller.
Old May 5, 2008 | 07:05 PM
riceburner700's Avatar
hondata all the way hands down
gsumano
May 2, 2008 05:13 PM
didder
Feb 21, 2008 10:42 PM
93sir
Oct 4, 2007 03:49 AM
sway2003
Dec 1, 2006 08:24 PM
tools52
Nov 16, 2006 11:45 AM
