safe psi on stock!!
Old Apr 29, 2005 | 04:01 PM
Nail I3unny's Avatar
Default RE: safe psi on stock!!
in the long run i think ud b happier w/ an engine swap. on D-series engines...the only thing u can really do to upgrade internals is pistons cams and maybe rods...they simply dont have the aftermarket B-series engines have
Old Apr 30, 2005 | 03:29 AM
Pete's Avatar
turbo would be better........more power for cheaper.
Old Apr 30, 2005 | 12:00 PM
se7ensectoolate's Avatar
Boost= Fun.
Old Apr 30, 2005 | 12:23 PM
Pete's Avatar
im banking every penny. Been for awhile now
Old Apr 30, 2005 | 12:59 PM
ngoti 8tor's Avatar
Boost it to 50psi, then you'd have a good reason for an engine swap
Old Apr 30, 2005 | 05:10 PM
CivicWonderland's Avatar
I found a web site that builds all out race d-series motors capable of double digit boost. They also build b-series as well. Here is the site. http://www.exospeed.com/ Hope it helps....
Old Apr 30, 2005 | 06:55 PM
Pete's Avatar
thats pretty sweet i must say.
Old Jul 13, 2005 | 09:17 PM
austin_Springer's Avatar
ok then what internals would i need to replace to crank up the boost?
Old Jul 13, 2005 | 09:38 PM
Pete's Avatar
how high do u want to boost
Old Jul 14, 2005 | 10:46 AM
Marty's Avatar
Stock MAP sensor on honda's will allow upto 11psi of boost from any turbo.
I read every reply in this whole thread and non stated the obvious......it is not allways "how many psi can I boost?" there are an aray of different turbo's on the market some making alot more power than others at any certain boost level.You need to find out which turbo you plan on running before trying to find out how much boost you are going to run.
For a good daily driver I'd say like a t25 or a 16g will be great,if your looking to push more power and have the potential to make more power down the road something like a T3 super 60 or a t3/t4 46trim will do good.
