smoke
hm...burning oil within the piping? im not sure. i would check the plugs and see if there is any change with those. also maybe take some piping off to see if there is oil within the piping. id say do a compression test as well to see if all your cylindars are working.
blow by!if your boosting your ringlands could of gone in one or multiple pistons(cracks and pieces coming off pistons), that is wat has just happened with my car!(same symptoms)or couldbe head gasket or valve trouble.i would do a comp test asap! check theradiator for bubbles and mayonaise.
Do you have any smoke coming out of your exhaust? Thats the same thing that happened to my car when I had broken ringlands. Does your car sound wierd at all? It could be the headgasket but its more than likely your ringlands starting to go causing blowby.
