STOCK D16Z6 ADDING EDELBROCK COMP. TURBO KIT
Old Jun 23, 2006 | 04:30 PM
ALDCSPECSI's Avatar
Default STOCK D16Z6 ADDING EDELBROCK COMP. TURBO KIT
I AM ABOUT TO ADD A COMPLETE TURBO KIT FROM EDELBROCK ON MY 95 EX COUPE. HAS ANYONE OUT THERE SEEN THIS KIT INSTALLED BEFORE, IF SO IS IT A GOOD KIT FOR EVERY DAY USE? ALSO I LIVE IN CALI. SO DO YOU THINK THE LOCAL PD WILL HARASS ME ABOUT THE KIT?
Old Jun 23, 2006 | 04:34 PM
Pete's Avatar
Default RE: STOCK D16Z6 ADDING EDELBROCK COMP. TURBO KIT
its a great kit. Is it CARB approved?
Old Jun 23, 2006 | 04:40 PM
ALDCSPECSI's Avatar
I AM BOT SURE IF IT IS CARB APPROVED. THE SHOP THAT IS INSTALLING IT SAYS THIS KIT IS STREET LEGAL.
Old Jun 23, 2006 | 04:44 PM
ALDCSPECSI's Avatar
WITH A GOOD TUNE, WHAT KIND OF HP/TRQ NUMBERS DO YOU THINK I CAN EXPECT?
Old Jun 23, 2006 | 04:50 PM
Marty's Avatar
For one thing turn your caps lock off.
Yes it is carb approved and with a good tune you will be able to make as much power as your Z6 can handle(220whp to 240whp)
Old Jun 23, 2006 | 09:24 PM
ALDCSPECSI's Avatar
Thanks for the heads up on the CARB approved status on the kit. What would be a safe amount of psi to run on stock internals? Also where can i locate some internals for my d16, to make it a little more "boost friendly"?
Old Jun 23, 2006 | 10:56 PM
blackeyes's Avatar
i woulndt goover 13, especailly so the cops could hear (i live in cali too). do you plan on buliding the motor?
Old Jun 24, 2006 | 12:37 PM
ALDCSPECSI's Avatar
I am trying to locate some stronger internals for my sohc, but my resources are limited. (due to the fact i am in iraq at the moment) Any idea where i can locate some?
Old Jun 24, 2006 | 04:39 PM
riceburner700's Avatar
you dont have to tune the edelbrock kit at all, just bolt and plug everything together and run some wires and you are ready for the street with the maximum power set... edelbrock tunes all there kits before they ship out there door... just a fyi
Old Jun 24, 2006 | 09:21 PM
Savatage's Avatar
Sorry to thread jack, but what about the complete edelbrock kit on a stock D16y8 w/ Skunk2 cat-back? what kind of number could i see?
