Super Charger HP+ also MPG+ ?
Old Jan 20, 2008 | 12:02 PM
carter15's Avatar
Default Super Charger HP+ also MPG+ ?
I read in one of the advertisements in a CarMagazine that a super charger can up your horse power aswell as fuel effenciy by up to like 30%????
Possible??
Old Jan 20, 2008 | 12:57 PM
riceburner700's Avatar
Default RE: Super Charger HP+ also MPG+ ?
the engine wont work as hard while cruising and you will get some better mileage if you keep your foot out of it, when you put the gas pedal down is when your mileage will go in the trash
Old Jan 20, 2008 | 05:25 PM
SovXietday's Avatar
MPG depends solely on the tune and driving style.
Old Jan 21, 2008 | 06:04 AM
didder's Avatar
your fuel efficiencly will definately probably not go up, your power gains could also be well over 30% with a little more psi and a tune...
expect your mpg to go down, but it will be worth it for the power gains you get
Old Jan 21, 2008 | 06:28 AM
Pete's Avatar
Turbos are better for MPG. When cruising on the highway I would get 45 or so mpg in my turbo d series.
Old Jan 21, 2008 | 08:00 AM
carter15's Avatar
Well aslong as you keep the RPMs low i would say that, you will be saving gas but once you start putting the pedal to the metal then youll see it decline but not by a hole lot tho? maybe 5mpgs?
Old Jan 21, 2008 | 12:56 PM
Mr Mobsta Man's Avatar
Depends on how often you get on it. If you do it alot then your mpg will probably be horrible plus paying for 91+ octane.
Remmy
Mar 13, 2007 12:55 AM
Civic03
14
Jul 29, 2005 07:07 PM
javierdagreat
22
May 19, 2005 11:29 AM
javierdagreat
May 18, 2005 07:02 PM
Super Mario
13
Oct 31, 2004 12:28 AM
