Turbo Civic Running Lean/Rich Check Code 22
Old Jun 16, 2007 | 06:15 PM
SovXietday's Avatar
Default RE: Turbo Civic Running Lean/Rich Check
OOO, MXS, thanks for the idea. Gotta add a new section to the FAQ.
"What do I need to do before being tuned"
Old Jun 16, 2007 | 06:31 PM
mxs's Avatar
mxs
word!
Old Jun 16, 2007 | 06:44 PM
SovXietday's Avatar
Added, feel free to check it out.
Old Jun 17, 2007 | 08:36 AM
Shingpumps's Avatar
Thanks alot, So the smoke may not be the rings , hopefully it's rich. I'm taking it to the dyno this week. We'll find out then.
Old Jun 17, 2007 | 10:40 AM
riceburner700's Avatar
if its to rich the fuel can wash out your rings and give you blowbye
Old Jun 18, 2007 | 10:02 AM
Shingpumps's Avatar
i still have to t off the drain line for the blowback too. T-ing off the drain is a legit way to deal with blowback, right?
Old Jun 18, 2007 | 11:15 AM
FlipHKD720's Avatar
wideband will give you an acurate reading, and defintely dont turst a narrow-band A/F gauge. Just dont go into boost and you will be okay, take it easy, and running rich is safer than lean, but still not good.
Also if you read the reviews from Phearable, there are quite a few guys that have had to make very few changes to the basemap they receive from Phearable, maybe you'll get lucky like them
Old Jun 18, 2007 | 02:10 PM
Shingpumps's Avatar
yeah, i hope so. I guess i'll see.
Old Jun 19, 2007 | 09:02 PM
closeing the turbo return line is a big no no. let it drain nice and free, i think your probably safe with fuel washing out your rings if it just isnt pooring out the exhaust with rich black sout. To prevent blow by of the rings is when you have to much pressure built up in the crankcase and pushes back on the piston as its traving up and down pushing the rings upward and lets some oil by.
Old Jun 21, 2007 | 12:21 PM
SE_2_EG's Avatar
Is the turbo used? It maybe just old oil still in the turbo, Mine did that for little bit, but it hasn't burned or leaked any oil. And untuned on 450s your engines probably choking on the fuel.
