Turbo an F22?
any thoughts on the motor powering the 8th gens and they're ability to produce power and handle boost on mainly OEM parts, or would internals need to be upgraded as well? I guess the question is, is the stock F22 strong enough to handle boost and not harm the motor or should i consider a swap? eventhough I do not think currently there is anything that will drop in.... just looking for some thoughts on this.
Thanks,
Josh
Thanks,
Josh
I dont think you have an f22 motor. Thats an S2000 block. There are boost kits available for your car. 7-8psi will definetly put a smile on your face. Your current motor should do fine with a careful tune.
ORIGINAL: Remmy
CivicN33b, you have an R18A1 i am pretty sure
