turbo at low boost in high compression engine
what is the deal with turbo charging a high compression engine?
is it possible if you use low boost pressure?
is is better since you have more low end torque?
what problems can you encounter with tuning?
i have a d16y8
bored 30 over,ported and polished,11:1 compression,with je pistons and skat h beam rods,
crower camshaft stage 1,crower valve springs and retainers,cyliner brace,shaved and balanced crank,calico bearing,arp studs.
plus all fuel updgrades (i.e. walbro fuel pump,aem fuel rail,venom injectors,holley fuel pressure regulator,and aem fuel filter)
i have a d16y8
yeah, with under 4-5 psi, good (at LEAST 91) octane, and some good igniton timing and dyno tuning, its possible to do. tuning is pretty tricky, but a good shop could handle it, and youll have awesome low-end power, with the turbo pulling hard on the top end.
rcgtsport
Jul 12, 2011 04:51 PM
Fiirkan
30
Jan 19, 2008 12:13 PM
FlipHKD720
30
Jan 7, 2008 02:36 PM
liliechen
Dec 25, 2005 11:15 AM
