Turbo Manifold
Old Sep 24, 2007 | 07:32 PM
FlipHKD720's Avatar
Default RE: Turbo Manifold
honestyl i wouldnt go for that if it was me. Pete put it well saying "shiny manifolds are crap, cast it where its at" I say stick with the HF, but if you're willing to do what Gene said and take teh time to buy it, install it and then dyno/before after, i'd totally be interested in seeing the results
Old Sep 24, 2007 | 09:13 PM
bcrichguitars's Avatar
I do want to get it and dyno tune it, but I don't understand how it could fit to my turbo because I have the adaptor plate welded on for the hf manifold. Could this be taken off even though it's welded? And also if i can get off the adaptor plate, will the manifold bolt right onto the turbo flange? Do I need to buy an inlet flange and get it welded on after the adaptor plate comes off?
Old Sep 25, 2007 | 11:50 AM
StifflersMom's Avatar
Cat Fuсker
wait, if the manifold is designed for your turbo there's no need for the adapter, the turbo should just bolt on...
Old Sep 25, 2007 | 02:40 PM
ORIGINAL: Roto
I know, but the problem is I currently have an HF manifold. There is an adaptor plate welded on the turbo. I'm asking is it possible for someone to take the adaptor plate off and would I need a new turbo inlet flange to be welded on?
I thought that this new manifold would flow alot better, i could get rid of the adaptor plate so it will be more direct flow, and it will look 10x better.
I'm very interested in doing this. Any ideas what I would need to do?
Old Sep 25, 2007 | 06:13 PM
riceburner700's Avatar
just buy another adapter plate and weld it onto the new mani!
Old Sep 26, 2007 | 06:37 AM
ORIGINAL: riceburner700
But then I have 2 adaptor plates. I dont want any adaptor plates, I wanted it directly to the turbo
ELECTRON BLUE 2000
Oct 4, 2007 03:25 PM
FlipHKD720
Oct 15, 2006 02:14 AM
98brokeassvtec
Mar 15, 2005 10:58 PM
TrailorParkPimp
Sep 6, 2004 05:23 PM
TrailorParkPimp
Aug 28, 2004 12:21 PM
