turbo oil feed orifice
Old Mar 23, 2007 | 04:28 PM
my_ef_is_boosted's Avatar
Default turbo oil feed orifice
I just installed a garrett T3 on my EF and now when it hits high boost it smokes i was wanting to know if it might need an orifice put in place to keep the pressure/volume down i dont know alot about boosted civics and anyone with any suggestions would be appreciated
Old Mar 23, 2007 | 04:34 PM
Street Sniper's Avatar
Default RE: turbo oil feed orifice
Umm, what? What kind of orafice? and what pressure volume are you speaking of?
How can you tell it smokes when it's at high boost? Seems to me that you would be moving pretty good at full boost and wouldn't be able to discernthe origin of smoke.
Old Mar 23, 2007 | 05:59 PM
SovXietday's Avatar
You can put a restrictor on it, but if the turbo's leaking it's going to leak at any boost level. It's just the way it works.
Sounds like you've got some other problems personally.
Old Mar 24, 2007 | 12:56 PM
riceburner700's Avatar
how is your compression?
Old Mar 27, 2007 | 02:28 PM
im talkin about in neutral when the turbo is spooled up it is blowin smoke out of the tail pipe i dont need to check my compression and just to let you know im a auto tech. i was just wondering that someone here might be able to answer my question not criticize my mechanical know how
Old Mar 27, 2007 | 02:31 PM
MY99SI's Avatar
did u get the turbo used?
if you did its probably somethign internal - compression and leakdown test
if its not then its the turbo seals on the exhaust side.. take off an I/C pipe and see if theres oil on the inside of the I/C pipes
Old Mar 28, 2007 | 10:11 AM
ORIGINAL: my_ef_is_boosted
Let me know where you work so I can avoid it like the plague...
One of many things is going on with your setup. Either the seals are shot in the turbo and its burning up that way, your old *** motor is burning oil, rings are going, etc.. Could be many factors.
Why do you think its unneccesary to check your compression? Its cheap, easy, and can tell you quite a bit about the motor
Old Mar 28, 2007 | 10:36 AM
how did i criticize your mechanical know how?
Old Mar 28, 2007 | 10:55 AM
StifflersMom's Avatar
Cat Fuсker
Wait a sec, you get your turbo to spool-up in neutral?
Old Mar 28, 2007 | 12:39 PM
the_turtle's Avatar
i dont need to check my compression and just to let you know im a auto tech. to answer my question not criticize my mechanical know how
well since your GOD then why are you asking us? and we dont hate, we love.
