turbo on stock motor
Old Mar 19, 2007 | 01:28 AM
97_ex's Avatar
Default turbo on stock motor
would it be smart to boost a d16y8 with 160k miles?? what would i keep the psi at?
Old Mar 19, 2007 | 01:29 AM
Pete's Avatar
Default RE: turbo on stock motor
Perform a leakdown and compression test. Give me the results and THEN i will answer this question.
Old Mar 19, 2007 | 01:31 AM
97_ex's Avatar
ORIGINAL: Pete
how do i go about that?
Old Mar 19, 2007 | 07:47 AM
Rent a compression tester from Autozone, should be like 40 bucks but you get it all back when you return it.
1 Take out your spark plugs
2 pull the fuel pump fuse (fuse box inside car)
3 Screw the tester into the number one cylinder
4 Put the accelerator all the way to the floor, and crank the motor for a few seconds.
5 Record the PSI reading for that cylinder
Repeat steps 3-5 for each cylinder and compare your numbers. They should all be within 10% of each other.
As for a leakdown, you're probably better off to take it to a shop. But, run the compression test first, that can tell you a lot.
Old Mar 19, 2007 | 09:39 AM
FlipHKD720's Avatar
Tony, what if they are all bad, but all equally bad? Like they are all within 10% of each other, but still at a number you dont want. How do you know? What PSI should they all be at?
And when you say crank the motor, do you mean rev really high?
Old Mar 19, 2007 | 10:14 AM
Fiasco's Avatar
leakdown test isnt thathard either if you have experience with your motor. If both that and the cylinder compressionare good, boost away!
Old Mar 19, 2007 | 10:25 AM
ORIGINAL: FlipHKD720
Its very unlikely that that would ever happen. There really is no SET number for what you should be getting, too many variables..
crank the motor means crank the motor, you can't rev it with the plugs out and the fuel pump fuse pulled
Old Mar 19, 2007 | 11:03 AM
FlipHKD720's Avatar
lol my bad.....well what is cranking the motor then?
Old Mar 19, 2007 | 11:26 AM
Remmy's Avatar
Cranking the motor is what you do every morning when you start your car silly.
And 10% is way too much. I would say no more than 5-7 psi from each other.
Old Mar 19, 2007 | 07:08 PM
97_ex's Avatar
i'll post results!
