turbo upgrade
hey ya people
as im in the crunch time of my build im gettin a bit anxcious as to have i enough added. type r head,b18c bottom end,wiesco pistons,eagle rods,arp bolts and studs,greddy head gasket,polished crank etc now im running garret t3 at the moment at 6 psi on stock b16a and i know i havent seen wat this turbo can do yet but i was wondering wot people thought? wat are the t3 turbos maxed out at? psi and bhp? and is their an uprated turbo i can get and keep the same mani etc.
ORIGINAL: Pete
you would make more power than u kno what to do with. If u want a really insane turbo get a GT35 ball bearing......ball bearing means instantanious spool.
like ill have it set at low boost most of the time. dont want to go ball bearing just a step up from the t3?
ORIGINAL: Remmy
if you have 500 you wouldnt be able to control it on the streets.
i was just checkin to see wat ye guys thought of the idea,thanks again peeps
