Turboing Stock d16y8
Old Aug 26, 2006 | 04:20 PM
Mr Mobsta Man's Avatar
Default RE: Turboing Stock d16y8
oh, what do you think I should do then?
Old Aug 26, 2006 | 04:44 PM
Meta's Avatar
Well, what are you shooting for HP-wise ?
Old Aug 26, 2006 | 09:14 PM
I gave up all hopes of an hp goal, with my engine and not wanted to pay for internals I just want anything that I can get without ruining my engine now
Old Aug 27, 2006 | 09:29 AM
96civic285whp's Avatar
Marty is making it more complicated than it really is. He's not going to put a t-70 or a t-88 turbo on his stock d. Just get a small turbo t3, and run 6-7psi. Make sure you run 91-93 octane, and get the car tuned or at least get a fmu. It would probly be a good idea to upgrade your fuel pump. I'd suggest a tial 38mm wastegate and a .5 bar spring. Make sure you have upgraded your exhaust as well. Make sure that you get an intercooler and i'd suggest a turbo xs type rfl blow off valve. With that you should make close to 200hp at the flywheel, give or take 20hp.
Old Aug 27, 2006 | 09:43 AM
Marty's Avatar
I know he is not going to run a turbo that big but I am honestly trying to get people away from using the psi term so much, each turbo is different, each setup is different, just because Joe Blow over here is running 14psi on a stock D from a T3 super 60 and making 250whp dont mean Joe Blow over there with the same setup will make the same power on the same boost level.
Old Aug 27, 2006 | 03:48 PM
I was thinking about http://www.evans-tuning.com/
whats a fmu?
Old Aug 27, 2006 | 03:59 PM
If you get a tune you don't need a fmu,(fuel managment unit) all it does is as boost increases it puts more fuel into the engine.
Old Aug 27, 2006 | 07:25 PM
What do they do when they tune a car?
Old Aug 27, 2006 | 07:35 PM
Set your air fuel mixture exactly right for all rpm levels, a fmu just does a set icrease per pound of boost, also with a tune they can adjust your timing. A tune is much more precise.
Old Aug 27, 2006 | 07:55 PM
i was reading on that site, what do they need to replace the spark plugs for?
