vac hose
im going to tap my brake booster line for a vac mani and i dont know whether to put the mani between the intake mani and the air restrictor located in the brake booster hose or after this closer to the firewall
thanks
thanks
Just to elaborate a bit, there is some sort of restrictor in the Brake Booster line. The way I have mine hooked up is that the hose with the restrictor is connecting my brake booster to my vacuum manifold, then the vacuum manifold is connected to the intake manifold. In talking with dfdon earlier on AIM, I had the thought that the restrictor should probably be placed between the vacuum manifold and the intake manifold, being as that is where the air is supposed to be restricted.
I'm not even sure if it matters, but it's something that probably shouldn't be overlooked.
skibum853
Sep 22, 2007 04:32 PM
