Want to build a motor for turbo... Swap??
Old Jul 29, 2007 | 03:41 PM
marspark's Avatar
Default Want to build a motor for turbo... Swap??
I am in the process of building a turbo for my stock d16z6. I am wondering, as I begin to think bigger, what motor should I build for my 95 sedan. A few opinions and advice would be much appreciated.
Old Jul 29, 2007 | 04:31 PM
Strong Island's Avatar
Default RE: Want to build a motor for turbo... Swap??
Sell the car and get a coupe or hatch!!!!! then worry about the engine for boost. just my $.02
Old Jul 29, 2007 | 04:56 PM
Lost's Avatar
Im lost here, your building a turbo for your Z6. But you want another motor?
Old Jul 29, 2007 | 07:27 PM
SovXietday's Avatar
Unless you want to do everything over again, just pick up another Z6 and build that.
Old Jul 29, 2007 | 08:09 PM
ej6buddy's Avatar
just get another z6 or y8 to build up depending on your plans (which you didn't mention)
Old Jul 29, 2007 | 08:21 PM
Pete's Avatar
Whats your budget? If its crazy big get a K20......thats a BIG budget thou. B18C is a popular choice as well. Sleeve and build it......add a GT35 and youve got anall outracecar.
Old Jul 30, 2007 | 08:35 AM
marspark's Avatar
My main concern is hurting my motor.AndIwould likeanother ready that will stand up to the extra hp with a turbo, and be able to start turning the turbo up on my built motor.
I guess my goals are 250-300 hp. Maybe something like 12-15lbs. I gotta keep the sedan though. I know it's heavier but I like the extra room. Small budget too... I guess another z6 sounds like the way to go. How much more is sleeving???
Old Jul 30, 2007 | 10:09 AM
johnny's Avatar
If you have a small budget, and you wanna make 250-300 whp on a D16z6, Its not happening. Your engine is good for 220whp (ish) What is your budget?
Old Jul 30, 2007 | 11:09 AM
SovXietday's Avatar
Sleeving is around 1000 or so, overkill for how much power you want though.
Old Jul 30, 2007 | 03:44 PM
marspark's Avatar
I guess as far as motors I was wondering if there was something way better that would be an easy swap for a z6 but if my motor is a good base that's cool too. As far as budget I am considering doing the motor over the winter or over6-12 months so 1000-1500 maybe more. I guess as far as goals I would like to squeeze as much out of my motor as possible without having to stand in a bread line. If I build a motor what are my other options?? Bigger turbo? More psi?? I guess I still need to learn more just to ask the right questions. Thanks again for the help.
