wat kit for H22a
Im on my way to purchasing a H22a, but i want to boost it right away! I want to do all the install my self at my dads shop! Im not sure wat kit to get for the H22 though? If anyone has any ideas or has heard of any good kits for the H series, it would be much appreciated for any input. Thanks Guys
RE: wat kit for H22a
a good GReddy or Turbonetics kit will do you nicely. of course you could peice a kit together yourself for cheaper.
Have you considered rebuilding the engine with forged/performance internals and then boosting it? Its gonna cost more and take longer but give you more power in the end.
yeah ive considered it but thats alot of extra $$ for internals right now! I plan to do internals in the long run.. Id like to go all motor but thats a ****-ton of work and $$... Thanks for the ideas and opionions though
Get a greddy, or turbonetics kit, dont run over 6 psi on stock internals. If you do, you'll have problems.
ORIGINAL: GotRice?99ex yeah ive considered it but thats alot of extra $$ for internals right now! I plan to do internals in the long run.. Id like to go all motor but thats a ****-ton of work and $$... Thanks for the ideas and opionions though |
^^ x1000
plus with the H22...down at the bottom they take up a lot of room. so you at LEAST want to replace your clutch/flywheel while the car is out. |
I've also heard that H22s have thin cylinder walls and are not so good for boost stock. Maybe you want to look into sleeves.
bah you dont need sleeves unless you plan on boosting over 20psi.
Alright...so if were thinking about fully built H22....How much am i looking at opposed to boosting right away?? I totally open to any suggestions i just want to know some others opions. Another thing? is the H22 really worth it over a B18? I mean i like the pricing of a H22 over the GSR swap or type-R swap! Ive also heard that H22 are heaving and makes handling ****y? True or False? And if TRUE is it that much of a big deal if its a tit-bit heavier? although it has more HP so doesnt it equal out? Im still learing soo bear with me and give all the info you have to your knowledge. Thanks guys
