Sponsored by:
Sponsored by:
where is the crank shaft sensor location on a 1.7 cdti 2005 mk7?
Old 09-05-2017, 10:40 AM
Charles Thomson's Avatar
Question where is the crank shaft sensor location on a 1.7 cdti 2005 mk7?
Hi guys my sisters car seems to be having a fuel problem where it seems to be running out of diesel even though plenty is in the tank!
i have change fuel filter, put on a primer beside it.
when i pump it it goes hard, though after its running it goes soft, when the enginge cuts out you need to fill the filter back up with fuel before it starts again (yes primer right way)
had a small code reader on it and it came up with the crank sensor code.
im guessing the sensor is faulty and not giving the signal to prime the fuel pump?
how easy is it to replace the crank sensor? i see a sensor on top of the engine bay driver side, i guess thats the cam sensor?
can anybody tell me how to replace this? guides for diesel cars are hard to find!
regards, Charles
Old 09-05-2017, 10:41 AM
codes
p0338
p1331
p0335
Old 09-05-2017, 10:43 AM
Old 09-05-2017, 10:47 AM
i can see these above sensors, are these any of them?
or is that too easy?
seems the part should look like this? just cant find it
packman
12-07-2014 05:34 AM
slotman
06-26-2014 10:44 AM
denisholden
03-24-2013 05:15 AM
burnindesirez02
04-21-2009 04:19 PM
Mario89
11-27-2006 09:31 PM
Quick Reply: where is the crank shaft sensor location on a 1.7 cdti 2005 mk7?
