2007 Si wheels on an LX
Old Aug 1, 2007 | 08:15 PM
mcgold79's Avatar
Default 2007 Si wheels on an LX
I just purchased a set of 07 Si wheelsfor my 07 LX coupe.Turns out the calipers are different between the Si & LX andone of the front wheels rubsthe caliper by just a fraction of an inch,the other clears with justpaper thin clearance.Has anyone ran into this problem? Arespacers the proper solution?It seems that about 2mm would be plenty, but I am not surehow much clearance is recommended to allow for heat expansion or other variables. Would shaving 2mm off thecalipers cause problems? I do not want to compromise the safety or reliability of my civic but I sure like the looks of the Si wheels!
Old Aug 2, 2007 | 06:39 AM
KarTuneMan's Avatar
Default RE: 2007 Si wheels on an LX
Depending on "where" the grinding is on the caliper....grinding some aluminum off of the caliper is a better plan than a spacer. No spacer = keeping the wheel under the fender where it belongs.
Old Aug 3, 2007 | 03:40 AM
Kommando's Avatar
ORIGINAL: mcgold79
Yeah, shaving calipers is a prettyeffective practice, as long as it's not shaved from critical areas.
Favors1
May 20, 2010 10:21 PM
Pete
Jan 19, 2008 12:28 PM
chase07
Dec 8, 2007 06:44 PM
ron_mexico
Aug 28, 2007 06:20 PM
