22mm sway bar, should I buy *pic*
Old Nov 7, 2007 | 10:51 AM
mill$civic's Avatar
Default 22mm sway bar, should I buy *pic*
This guy is selling this on a local forum and it looks like a good deal, but any experts want to give me a heads up on anything let me know. I talked to him and he says everything I need to bolt it on comes with it. Should I do it?
22 mm swaybar and tie bar, All hardware D brackets bushings and
endlinks inlcuded, a little dirty
[IMG]local://upfiles/2140/64DF9736342E478D893A5149343660E9.jpg[/IMG]
Old Nov 7, 2007 | 11:02 AM
danomatic93's Avatar
June 2010 ROTM
Default RE: 22mm sway bar, should I buy *pic*
That looks an awful lot like an OBX one on eBay for 100...
http://cgi.ebay.com/ebaymotors/OBX-S...spagenameZWDVW
Hopefully, you're getting it cheaper than that from this guy.
Old Nov 7, 2007 | 11:14 AM
mybrokenblinker's Avatar
I like my 22mm, just make sure you have some form of subframe reinforcement.
Old Nov 7, 2007 | 11:31 AM
mxs's Avatar
mxs
ORIGINAL: danomatic93
No way... that one is a cheap knockoff. The one in the original post looks like the Suspension Techniques kit that I have. The small bar IS the subframe reinforcement. That's beefy, I'd wait until spring to install it
Old Nov 7, 2007 | 11:45 AM
June 2010 ROTM
ORIGINAL: mxs
I stand corrected...
http://images.google.com/imgres?imgu...3Doff%26sa%3DN
So, 300 bucks.
Old Nov 7, 2007 | 11:52 AM
mxs's Avatar
mxs
Yeah, that's the one
Old Nov 8, 2007 | 07:39 AM
mill$civic's Avatar
Ok thanks, I think I'm going to buy it in a couple days, andI will wate till spring to install it. I'm pretty excited about thegood handling I will hopfully get from it.
Old Nov 8, 2007 | 12:16 PM
Nerosync's Avatar
I don't know how much your paying for it but I don't really like how many pieces it is constructed out of. What I mean is the tie bar and the sub frame reinforcements etc. are all seperate pieces. It also looks like it has been on something for awhile by the looks of the rust on the brackets. I would make sure the bushings and end links are all in good shape before you buy it. I would suggest a stronger one piece design like the Progress combo I put on my Civic shown below:
[IMG]local://upfiles/26094/84E1B45B0C61414781737CC64BC834B5.jpg[/IMG]
Old Nov 8, 2007 | 12:38 PM
get the kit from the friend for the reduced price, you won't notice any difference.
Old Nov 8, 2007 | 06:03 PM
mill$civic's Avatar
Hey MXS, If you have the same one if you could just help me, he said that he dosent have extended LCA bolts, he used OEM ones, will this work?. The end links are OEM non adjustable, is that fine?. One last thing, its just the bar that bolts on to the subframe, then the sway bar gets put onto that, there is no metal backing that goes on the other side of the subframe, is that right? Just the brace gets bolted on to the frame, and the sway bar to that and Im good?
Thanks
