96 civic EK Brakes
Anyone know how to put on the round thing that pushes the pads together?
When i was installing my new brake discs the fitting wouldnt go in and i pulled it out by mistake and cant get it back in. Help pleeeeez :( |
RE: 96 civic EK Brakes
Are you referring to the piston thing inside, or the caliper itself?
the bes thing to buy when you get a new car is a haynes manual. it tells you how to change everything on your car
I think you are refferring to the piston that is located inside the caliper as forty mentioned. If you want to push this is, you will need a c-clamp. Take some of a fluid out of the master cylinder with a rag. Now push the piston in with the c-clamp. This only works on front calipers that do not have an attached e-brake. If you try this on a caliper with an emergency brake, you will break the caliper.
yeah, the piston in the caliper. ok, i've got it in but now i have no brakes?????
we dont get haynes manuals in south africa.... i think |
