96 civic EK Brakes
Old Apr 10, 2006 | 12:11 PM
POIZN's Avatar
Default 96 civic EK Brakes
Anyone know how to put on the round thing that pushes the pads together?
When i was installing my new brake discs the fitting wouldnt go in and i pulled it out by mistake and cant get it back in. Help pleeeeez
Old Apr 10, 2006 | 01:46 PM
Default RE: 96 civic EK Brakes
Are you referring to the piston thing inside, or the caliper itself?
Old Apr 10, 2006 | 06:33 PM
civic8882's Avatar
the bes thing to buy when you get a new car is a haynes manual. it tells you how to change everything on your car
Old Apr 11, 2006 | 12:44 PM
AgentofDarkness's Avatar
I think you are refferring to the piston that is located inside the caliper as forty mentioned. If you want to push this is, you will need a c-clamp. Take some of a fluid out of the master cylinder with a rag. Now push the piston in with the c-clamp. This only works on front calipers that do not have an attached e-brake. If you try this on a caliper with an emergency brake, you will break the caliper.
Old Apr 11, 2006 | 03:49 PM
POIZN's Avatar
yeah, the piston in the caliper. ok, i've got it in but now i have no brakes?????
we dont get haynes manuals in south africa.... i think
jonsaidthat
May 30, 2010 09:30 PM
ahhsimon
Jun 14, 2006 09:52 AM
oldschool
Dec 21, 2004 10:03 PM
faceless_civic
Nov 17, 2004 10:19 PM
NTX
May 7, 2004 11:25 PM
