ABS problem
Old Mar 11, 2009 | 09:03 AM
vtecaddict's Avatar
Default ABS problem
so my abs isnt working, and hasnt been since a bought the car about a year ago. it will work sometimes and the light will go off after heavy rains for a few minutes then the light will cone back on and the abs will quit working, so im thinking it has a grounding issue. i've replaced the abs computer already so i know thats not the issue. and i have another su****ion that it could be the relays up front, but i have no clue what the part number is for a 93 ex. is there anyway to pull the abs code like you would the engine code? my trunk leaks a little from wheel well rust, causing it to maybe complete a circuit during a heavy rain?
Edit: so apparently i cant say s u s p i c i o n on this thread thats what su****ion is
Old Mar 11, 2009 | 09:15 AM
Jump the service connector to pull the ABS codes from the ABS ECU.
Old Mar 11, 2009 | 09:16 AM
vtecaddict's Avatar
do i need to go to the dealer? of is there a special way to do it im not familiar with?
Old Mar 11, 2009 | 09:22 AM
No, see my edited post above. It's just like pulling CEL codes. Troubleshooting the ABS code(s) can be found in the 92-95 service manual at the link in my signature.
Old Mar 11, 2009 | 09:25 AM
vtecaddict's Avatar
thanks Ron. ill try doing this later today. you're a great asset to this forum.
Old Mar 11, 2009 | 09:28 AM
Hey, no problem. This way you can pinpoint the problem without randomly replacing parts.
Old Mar 11, 2009 | 10:08 AM
vtecaddict's Avatar
it flashed once, then the check engine flashed, im guessing that means its a faulty pressure switch. now i just gotta see if the manual says where its at...
Old Mar 11, 2009 | 10:10 AM
Looks like possibilities are a faulty pump motor, solenoid, or pressure switch. You'll need a digital multimeter and a special bleeder wrench to troubleshoot (see manual pages 19-61 and 19-62).
What CEL code was found?
Old Mar 11, 2009 | 10:13 AM
vtecaddict's Avatar
just one long flash on both then it repeated abs then check engine
Old Mar 11, 2009 | 10:21 AM
You have either CEL code 1 (one short blink) or 10 (one long blink) = O2 sensor or intake air sensor.
Clear the ECU to determine whether the CEL code returns.
