ABS Question
When braking at high speeds i get a vibration in the wheel and pedal....i have never had abs before is it them kicking in? It doesn't do it when braking at low speed and I have check the rotors and both them and the brakes a almost new. I know this is a newby question... but i'm learning. I took it to the honda dealers and one said i needed to turn the rotors and the other said that they were like new... my ex looked at them and said they were like new too.
RE: ABS Question
i dont think we could really tell you unless we could feel it, but it shouldent be kicking in when your breaking at highspeeds, it will kick in if it sences your wheels are slipping..if its abs you will no, its really big palse's ..if the roads or coverd in snow or its really slipery out side, go find a safe place and drive and slam on the brakes..you dont have to go fast eather,as long as your wheels start slipping..and then you can what abs feels like, abs feels like your pushing on the brakes really fast when your not..you will be able to feel the brake pressure build up and release really really fast when your holding the brake and the abs kicks in
RE: ABS Question
The dealer could be right, the rotors could have runout in them and it will cause pedal pulsation when braking and i think (am not completely sure) that the steering wheel will also have shimmy (vibrate/shake). If you think that it is warped rotor then pull them off and take it to a parts store and have them turned.
RE: ABS Question
It sounds to me like the rotors (or maybe one of them) are warped......if the ABS kicks in it will feel like you hit the rumble strip on the interstate only more violent.....it scared me the first time I felt it, I thought I had broken something. It is not a big deal to have them turned as long as you know how to pull them from the car. If the brakes are almost new, did you have them installed professionally? If you did, I would guess you have some sort of warranty and can take them in and have them looked at. If the rotors are warped but new (never been resurfaced) they can turn them to smooth them out and they should be less likely to warp again (once they heat up the steel tends to harden).
Hope this helps! G |
RE: ABS Question
Yep brakes are new installed by honda.... only cuz it was under warrenty.... and when I had it checked last they were not worn at all. I think i'm gonna pull them off tomorrow and see if I can find someone to turn them for me since they have never been resurfaced.
Thanks all of you guys for your input.... i'll let you know if turning the rotors helps.... Fran ORIGINAL: trickyvick It sounds to me like the rotors (or maybe one of them) are warped......if the ABS kicks in it will feel like you hit the rumble strip on the interstate only more violent.....it scared me the first time I felt it, I thought I had broken something. It is not a big deal to have them turned as long as you know how to pull them from the car. If the brakes are almost new, did you have them installed professionally? If you did, I would guess you have some sort of warranty and can take them in and have them looked at. If the rotors are warped but new (never been resurfaced) they can turn them to smooth them out and they should be less likely to warp again (once they heat up the steel tends to harden). Hope this helps! G |
RE: ABS Question
make sure the lugs are tight. it could be alignment, or your wheels/tires may need to be balanced. also, a rotor like the other guys said. probably not the abs.. that engages when you are locking the brakes up.
RE: ABS Question
Thanks ... I'll make sure I check those too...
RE: ABS Question
Depending on where you go, it may be cheaper to buy new rotors.
RE: ABS Question
ORIGINAL: mxs Depending on where you go, it may be cheaper to buy new rotors. |
RE: ABS Question
ORIGINAL: mill$civic it will kick in if it sences your wheels are slipping It sounds like either one or both rotors are warped. |
