Aceptable tire size
Old Sep 8, 2007 | 03:08 PM
moemullet's Avatar
Default Aceptable tire size
Neebie to this forum. Could not find the asnwer to a simple question concerning acceptable tire sizes for my totally stock 93 Civic with 13 inch rims. Stock tire size is 175/70/13.
Can I safely put 185/70/13's on these stock rims without rubbing concerns? What about 195's?
Thanks for your help in advance
Old Sep 8, 2007 | 06:00 PM
conceptualpolymer's Avatar
Default RE: Aceptable tire size
Besides your pitifully small OEM tires/wheels your acceptable tire/wheel sizes are:
185/60/14
195/50/15
205/40/16
I would upsize to either of the latter two sizes. Everything else is like choosing which donuts you want to ride on.
Old Sep 12, 2007 | 01:26 PM
Kommando's Avatar
ORIGINAL: moemullet
The 185/70s are going to be wider and taller than your stock tires. Depending on the stockrim width, the tires may be too wide to wear properly. You may want to upgrade both the rims and the tires.
If the 185 tire width is ok for your stock rims, you'll want a 60-series tire to keep the overall tire diameter correct.
Old Sep 12, 2007 | 06:19 PM
Champ white FD2's Avatar
195/60/13.....
Old Sep 12, 2007 | 07:18 PM
R35P3KT's Avatar
just a fyi 215/45/17 work as well
Old Sep 23, 2007 | 03:01 PM
moemullet's Avatar
Thanks for the help.
This Civic is a beater that I drive for my job. I do not intend to upgrade this ride as Idrive it strictly for the mileage.
Thanks again.
Old Sep 23, 2007 | 03:12 PM
well then just stick with stock size........
with swaping out the size on stock rims will throw off your speedo and youll be going faster than the speedo says.....
so just stick with stock and keep your speedometer correct...
ballplaya4eva07
May 26, 2005 06:28 AM
fastman90
Apr 22, 2005 03:23 PM
INJENalltheway
Dec 28, 2004 08:06 PM
jablalock06
Nov 19, 2004 04:05 PM
zaidomar
Nov 17, 2004 01:06 PM
