Before I Lower
Ok so I have a ej2 and i want to buy either Skunk2 or Tien lowering springs. I only plan on lowering the car 1.5-1.75 inches but i would like to know 1) if a spring compactor is the only special tool i need 2) If ill need an alignment afterwards 3)will i need camber and if i do would it be ok to roll around without messing with the camber because i want to lower it really bad but i dont have the money to buy quality camber kits right away. thx
A spring compressor and basic hand tools is all you should need, assuming you don't run into problems with the rear LCA bolts being seized. You will 100% most definitely need an alignment afterward, but wait a week or two for the springs to settle before getting everything aligned. I promise you won't destroy your tires in that week or two. And also, don't worry yourself over a little negative camber; as long as the toe is set back to factory specs, you won't go through tires any faster.
I can breathe easy now
(Post 591397)
thx again |
No problem... changing out the springs isn't too hard. The hardest part is putting the struts back together in the right order (and getting the rear struts back on... that's a PITA lining up the lca with the shock and getting everything bolted together).
Honestly, if I were you, before I even started, I'd spend the extra $40 or $50 and get polyurethane rear shock mount and rear LCA bushing sets. Also, getting brand new replacement bolts wouldn't hurt either (another $30 or so from honda). You might not like the idea of spending an extra $100 at first, but trust me, if one of the bolts on the rear LCA is seized up, you'll be thanking God you have a new bolt and bushing, because you'll need it. And if you don't have any problems with the bolts seizing, you'll have nice new bolts and poly bushings :D. Also, I'd advise you start with the rear springs first. That way, you get the hard part out of the way early. The front springs won't take long at all, I changed out a shock by myself with basic hand tools in less than an hour, and the car in question sat all of 4" off the ground, so it took a good 10 minutes just to get the thing jacked up lol. *edit: live axles ftl lol... every time I hit a bump in the mustang, it feels like I have no rear suspension at all lol |
(Post 591412)
yeh u dnt have to change the camber kit or anything, i dropped my car about 2" and i only put tein coil overs and changed the rear shocks as they were finished and put kyb shocks instead...no problems whatsoever going over any speed bumps
Originally Posted by lilgreencivic
(Post 591377)
Originally Posted by conceptualpolymer
(Post 595055)
That's a perfect drop in my opinion. That's what I did with the Eibachs; my hatch looks great and I can fly over parking lot entrances and driveways without any scraping.
if you get snow in your area id suggest getting some good coilovers like ground controls...
i love mine! coilovers FTW because you can adjust them really easily and drop the car exactly where you want it!!!!!!!! and in the winter just crank up the perches and be close to stock height again for max ground clearance, and in the spring crank em back down. you cannt go wrong! ;) |
(Post 595080)
