Brake dust shield
Old Jan 27, 2007 | 02:42 PM
psychocivic's Avatar
Default Brake dust shield
HOW DO I REMOVE THE DUST SHIELDS!!??!?!?!
i thought it was just being held on by a couple of bolts on the back of the rotor, i guess not though. do i actually have to take off the rotor in order to take the brake dust shields off? thanks
Old Jan 27, 2007 | 03:04 PM
mxs's Avatar
mxs
Default RE: Brake dust shield
why?
Old Jan 27, 2007 | 03:17 PM
civicexracer's Avatar
i think its more of a brake duct kinda thing than a dust shield. if u look at it, toward the front ofit is kinda open as if it were mentto help guide air to the brakes. either way, why would u wana take it off?
Old Jan 27, 2007 | 03:31 PM
well i adjusted my ride height the other weekend and for some reason at the bottom of the rotor the shield gets pinched between the rotor and a bolt while turning left . i got an alignment on thursday and new tires in the front but that still didn't change anything. so i just want to take the shield off.
Old Jan 27, 2007 | 03:35 PM
mxs's Avatar
mxs
what bolt? just bend it out of the way?
here's an old picture of my hub with no rotor, I still don't see the fasteners
[IMG]local://upfiles/4155/0C5DB97790C949BFA53B836431AEB4A7.jpg[/IMG]
Old Jan 27, 2007 | 03:41 PM
its a bolt thats behind the shield, i didn't take a look at what part of the control arm the nut was for but its like..........nut>shield<rotor. so if you look behind the shield where the axel is you will see what i'm talking about. but now i at least see that i need the rotors off in order to take the shields.
it wont hurt anything if i do take them off will it?
[IMG]local://upfiles/5289/C281C1B291214BF0B8EC289540010AF8.jpg[/IMG]
Old Jan 27, 2007 | 03:53 PM
only nut i kno of thats back there is the ball joint nut...which u would not want to remove.
Old Jan 27, 2007 | 03:55 PM
well yea i'm not gonna remove the nut just the shield
Old Jan 27, 2007 | 03:57 PM
ya if u take off the ball join nut u can swing the rotor out and prolly remove the sheild. u'll prolly need new cotter pins for the ball joint nut if u do that.
Old Jan 27, 2007 | 04:07 PM
but wouldn't i be able to take the shield of if i removed these 2 screws and that disc thats on the wheel studs? i.e. picture below
[IMG]local://upfiles/5289/B162C0AD10004FDC986B3ED9BEAA7A07.jpg[/IMG]
