brakes goes straight to floor
Old Jun 12, 2007 | 02:21 PM
Blackice's Avatar
Default brakes goes straight to floor
when im driving somtimes my brakes goes all the way to the floor does anyone know what the problem is
Old Jun 12, 2007 | 02:23 PM
ej6buddy's Avatar
Default RE: brakes goes straight to floor
air in the system, bleed them out, then try again.
p.s. from your screen name, i'm guessing you had a bad experience?
Old Jun 12, 2007 | 02:41 PM
Blackice's Avatar
how do i do this?
Old Jun 12, 2007 | 03:27 PM
Fiirkan's Avatar
If you don't know how, take it to a shop and have them do it. Chances are if you don't know how to bleed the brakes, then even if we explained it to you, you may not understand(no offence) but i get the impression that you are fairly new at this stuff
Old Jun 12, 2007 | 03:40 PM
Blackice's Avatar
yea im fairly new to this. how much do you think it would cost for them to bleed the brakes?
Old Jun 12, 2007 | 03:54 PM
ej6buddy's Avatar
not too much, and it varies from shop to shop, i always do it myself, so i don't really know a good estimate for it.
Old Jun 12, 2007 | 06:10 PM
Blackice's Avatar
allright my friend just bleed the brakes but it still does it he says probally i need a master cylinder wat do you think?
Old Jun 12, 2007 | 06:23 PM
conceptualpolymer's Avatar
Either you DO need a master cylinder or you have a big leak somewhere. If you do get a master cylinder, don't let anyone pump the brake pedal to the floor, years from now when the brakes are bled. It won't hurt with a newMC, but overextending the piston in a used MC will damage its seals. Some people place a block of wood under the pedal when they blooed the brakes. This is a good idea if it is done manually.
Old Jun 12, 2007 | 06:40 PM
Blackice's Avatar
should i just go ahead and order the master cylinder or take it to a shop?
Old Jun 13, 2007 | 03:04 PM
Blackice's Avatar
im try bleeding the brakes again it only goes to the floor when im parking or when i just start the car has anyone ever had this problem?
