camber kit?
Old Feb 16, 2006 | 03:33 PM
Mark's Avatar
Default camber kit?
i have eibach lowering springs on the car and the rear wheels are a little bit angled now. well i guess more than a little because im getting excessive tire wear on the inside tred. my question is would a camber kit solve this or are there better and/or cheaper ways to solve this?
Old Feb 16, 2006 | 03:37 PM
91crx_87's Avatar
Default RE: camber kit?
Camber kit will stop any additional wear on the inside but you may need new tires, i put a full four wheel kit on my car and it has great traction now. Definitely worth it.
Old Feb 16, 2006 | 03:40 PM
Mark's Avatar
no i already have the new tires. i meant on the ones i took off
Old Feb 16, 2006 | 05:00 PM
97_nw's Avatar
camber kit will fix it without a doubt. did you get an alignment right after you got it lowered though? if u didnt, that will kill you tires faster than negative camber/toe. ive been lowered for about 4 months, -1.7 on the rear and i have no tire wear issues yet.
Old Feb 16, 2006 | 06:41 PM
polo708's Avatar
if you are just on springs then get a standard alignment done and that will fix all you camber/toe issues. This should be done anytime the suspension is changed... camber kits will fix the problem but are more expensive and arent NEEDED.
Old Feb 16, 2006 | 06:50 PM
Mark's Avatar
thanks thats what i needed to hear
Old Feb 16, 2006 | 08:20 PM
91crx_87's Avatar
for my car the camber was too far out of whack for a standard alignment to fix it, i had to get the camber kit. it depends on how much you have lowered/changed the suspension.
Old Feb 16, 2006 | 09:04 PM
Mark's Avatar
i dont quite know cause they were on the car when i bought them. i believe its like 1.5" or so
Old Feb 16, 2006 | 09:22 PM
SITNLOW97's Avatar
Then yea a alignment will fix it!!
Old Feb 17, 2006 | 11:34 AM
polo708's Avatar
ORIGINAL: 91crx_87
I take it you have coilovers and are dropped somewhere int he area of 3" or more... in that case then you you will need a camber kit. But for springs they arent needed.
