camber kit
Old Mar 29, 2005 | 06:58 PM
cage2b's Avatar
Default camber kit
Question, it's getting to the point that I just might have to get a camber kit for my coupe. Any suggestions? Should I start out with the front ones first since it wears out the quickest? If so, what kind? Mod: Koni Adj with Eibach Pros.
Old Mar 29, 2005 | 10:15 PM
Kappa22's Avatar
Default RE: camber kit
If you can only get one at a time, get the front one first, since it almost always has a lower drop and thus more camber problems. I would look at the skunk2 kit if you can find it. I think sacicons had some hookup or other to get them rather cheap... might be too late now though.
Old Mar 29, 2005 | 10:23 PM
ohbiskits's Avatar
ORIGINAL: Kappa22
I would look at the skunk2 kit.
took the words right outta my mouth..
Old Mar 29, 2005 | 10:48 PM
Dickie's Avatar
Member
if not the skunk2, at least get the same design as they are, its the best design out there
Old Mar 30, 2005 | 02:28 AM
NTX's Avatar
NTX
i'd get the rears first.
Old Mar 30, 2005 | 12:19 PM
riceburner700's Avatar
revo makes the exsact same looking kit as the skunk 2 kit but just without the brand name on it,,,,,works exsactly the same....you can get the revo front kit off ebay for pretty cheap and they also have skunk 2 ones on there to.
Old Mar 30, 2005 | 05:08 PM
jwsimons's Avatar
AN ALIGHNMENT SHOP CORRECTED MINE FOR LESS THAN (0oops) the cost of the kit, including alignment. they bent the knuckle to correct it for $160.00. and no worrys about slipping out if you hit a pothole or ?
and sorry for yelling in the start
Old Mar 30, 2005 | 09:16 PM
sacicons's Avatar
wow, i could have gotten a kit for way less than 160. and i can get them pretty cheap, but my guy is out of town a lot, so ill try to get a few from him when hes here, then ill post up when i have some stuff for you guys.
Old Mar 30, 2005 | 11:59 PM
jwsimons's Avatar
it was 160.00 out the door, labor and alighnment all four wheels, camber kits were like 100.00 for a pair ,plus install and alighnment, and it is continual with a kit, you need to check it periodicaly. i feel i got out o.k. on this. there is no way i could afford the frame bender they used, this is also the one thing i have not done to the car myself. all my other mods are done by me.
Old Mar 31, 2005 | 12:09 AM
sacicons's Avatar
oh, ok, that included the alignment. thats not too bad then. but ive never had mine slip.
larring1020
Dec 8, 2006 12:55 AM
mr2insane
Mar 1, 2005 01:15 AM
aijai28
Jan 4, 2005 07:54 AM
steven87ukuk
Oct 29, 2004 06:32 PM
joeyjoejoe
Jul 11, 2004 07:07 PM
